04-20-2006, 04:32 AM
#1
Thermaltake Tidewater?
After reading tons of reviews that all say VERY diferent things about the thing I am wondering if anyone has this or has tried this. If I were to buy this it would cool my 1900xtx and I would not overvolt, but would up the core as far as it'll go on stock volts. Some reviews say 50max laod others say 75... really confused. The reason I am not going with a real wcing system is because its too much of a hassle to fit it all in my case and ti'll be twice the cost. Anyone know something about this that i should?
04-20-2006, 04:40 AM
#2
Xtreme Cruncher
Just looked at a couple of reviews, given that it holds X800 series cards to 45-50 deg C full load at stock, I wouldnt bother with it for an X1900XTX. It might deliver better temps than the stock cooler, but not by much so its price/performance ratio would suck IMHO.
Not sure what pricing is like in Canada but in the UK the Tidewater is £50 and £75 gets me:
Eheim 600lph pump/res station
Alphacool 120mm rad
Alphacool 7800/x1800xl block
2m 10/8m tubing
__________________
Gigabyte X58-UD5 | i920 | 3x2GB Value DDR3-1333| 2xHD4870 + HD4850 Tri-fire| Ultra 1KW PSU | Lian Li V1200 | Watercooling by Thermochill, Laing, Swiftech, XSPC & HW Labs
04-20-2006, 04:55 AM
#3
Xtreme Mentor
Don't bother with it. Your X1900xtx will be better with the stock cooler.
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
04-20-2006, 11:40 AM
#4
I am doing this mostly for silence though...
04-20-2006, 02:04 PM
#5
Xtreme Mentor
It's your call.
__________________
Watercooling setup:
04-20-2006, 02:30 PM
#6
Xtreme Mentor
Invest the money in a real water cooling solution.
__________________
PC Lab Qmicra V2 Case SFF
i7 950 4.4GHz 200 x 22 1.35 volts | Cooled by Swiftech GTZ - CPX-Pro - MCR320+MCR220 | Completely Silent loads at 66c
GTX 260 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II | Xigmatek Northbridge cooler mounted to the stock system.
OCZ Vertex RAID-0(60Gig x 2) | WD 1000Gig Storage
Enermax Liberty 620| With a low speed yate, the stock ball bearing fan crapped out after 1 year of service.
04-20-2006, 02:33 PM
#7
Xtreme Guru
get a Swiftech Storm
and everything else from Danger Den website trust me, if you can!
Don't worry about a res. just do a T line in your loop. For me although sloopy looking I did a 6' loop (longer then most peeps). It's longer because it holds more coolant, thus keeping your CPU cooler. If you do a short loop 3' or less I suggest you get a res as the added coolant will help more then just relying on the Rad w/fan only, IMO.
I say this because I did some investigating and it paid off in the end (6' long loop). It pays to have more coolant with your WC then anything else.
Goal:
Is to get your CPU, GPU or CPU/GPU as close to ambient temps as possible. Once you get it below ambient temps under load you are getting some extreme cooling without a phase...
Koolance Exos-2> Thermaltake at watercooling
Just my 2 coppers worth.
__________________
04-20-2006, 02:35 PM
#8
i dont belive you! show me!
__________________
Originally Posted by Jimmer411
Tho personally Iam wishing I had more girth than length. This skinny thing I got just dont get the job done anymore. The wife agrees.
04-20-2006, 02:39 PM
#9
and everything else from Danger Den website trust me, you can't go wrong!
I actually have a full out wcing system with a strom iwaki bix3 and a maze4, but since I moved to phase I am selling all that soon, right after I refill it and patch it up. Selling it already all mounted into the case to a friend of mine for like 1/3 of what i paid for it. Sooooo I only need gpu cooling since I got cpu covered with a chilly1 single stage. By now I am thinkin screw the tidewater and go with some aircooling solution. I am in canada so even the CHEAPEST decent setup would cost 200+. I have calculated this many times and unfortunately this is true. Thx for the help.
04-20-2006, 02:43 PM
#10
Xtreme Mentor
There's not a better aircooling solution than the stock x1900 cooler out there as of now.
My 2 cents.
__________________
Watercooling setup:
04-20-2006, 02:51 PM
#11
keep the maze 4 an det a single pro and a decent pump!
__________________
04-20-2006, 02:52 PM
#12
Xtreme Guru
In that case then, lap your HS as some come with the drill cuts. Once I lapped mine load temps dropped from 75C down to 64C (don't think I mentioned that in my link). And, one time I forgot to plug the fan in (I re-alcoholed the HS again to make sure I removed any oils) when I looked at the temps it was unusually high at idle. Then it dawned on me  I forget to plug the fan in. I took a quick snap shot of it then immediately turned it off. It was left on for 45 minutes before I relased this  That's nothing to sneeze at...
link
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
