XtremeSystems Forums
Reply
Old 04-18-2006, 05:39 AM   #1
JoeBar
Xtreme Mentor
JoeBar's Avatar
Cool It's time to do business...
After a trip to wc with entry level kits (eg Tt) i've decided to build up something serious...
Let me begin with my case which is a Tt Kandalf. I'm thinking of using a triple external radiator on top of the case.
The parts i'm interested in are:
Pump: The contenders are
a) Laing D5 with Danger Den Dual 5.25 reservoir.
b) Laing DDC Ultra with water tank
c) Third choice AquaXtreme 50Z with Danger Den Dual 5.25 reservoir.
I'm leaning towards the sheer power of the D5. However i'm a bit concerned adout its noise. Can u give me your input? If it's too loud and i'll run it @ number 4 setting, how does it compare to DDC Ultra regarding noise/performance? One more thing that bothers me is that DDC Ultra comes with 1/4 threads, isn't that a bit restrictive for the pump? Before u start proposing me to use a T-Line let me inform u that i would prefer a reservoir instead.
Radiator: As for the radiator there are two possibilities. The first one is to go for a normal triple radiator with 3 Thermaltake A2018 fans, push or pull. Here we have two options:
a) Alphacool NexXxoS Pro III
b) Black Ice Pro III
The second option and the one i'm leaning to, is to go with an extreme triple rad with 6 fans running @ 1700 rpm (the above mentioned) push/pull config. Here the contenders are:
a) Alphacool NexXxoS Xtreme III
b) Black Ice Xtreme III
c) The beast. Thermochill PA 120.3. I know of course that PA is the better one but i would like to know if it'll give me lower temps with my setup to justify its higher price.
Bear in mind that with any radiator setup i'll go with theese stands.
Waterblock:. The options here are:
a) AquaXtreme MP-05 Pro Limited Edition
b) AquaXtreme MP-05 SP Limited Edition
c) Least favourable. Danger Den TDX
Tubes:. Here we have.
a) Dander Den 1/2 ID UV green
b) Tygoon 7/16 ID or 1/2 ID
What do u guys think? I'm tempted from the lower diameter of the 7/16 Tygoon i would have liked it to be UV though...
U may ask by now where is VGA wc? Due to my relatively "tight" budget i won't go for it now and leave it for the future (not that long though ).
That pretty much covers it all.
Sorry for the long post guys but after several attempts with wc kits, i wan't this time to do it right...
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
JoeBar is offline   Reply With Quote
Old 04-18-2006, 06:20 AM   #2
Radical_53
Radical_53's Avatar
Send a message via ICQ to Radical_53
I can't tell you anything about the noise of a D5, but a DDC+ gives you decent performance and is really silent.
If you have a tight budget, I'd go for the MP-05 SP, BI Pro and maybe Masterkleer tubing? Tygon is really pricy.
What you definitely should not get is the Nexxxos rad and the TDX block. Both really aren't great performers.
__________________
Intel Core 2 Duo E8500 | MSI P45 Neo2-FR | OCZ PC2-9200 Reaper HPC | Zotac GTX 285 | SilverStone TemJin TJ-03 Nimiz | Enermax Modu82+ 625W
EK Supreme | Watercool GPU-X² | Thermochill PA 120.2 | Petra's Tech DDCT-01 w/DDC-2
Radical_53 is offline   Reply With Quote
Old 04-18-2006, 06:46 AM   #3
eXa
eXa's Avatar
if you got the money; pa 120.3 or else pro3. dont know wich fan u will use, but bix i only better than pro with 100cfm+ fans
but instead of pro you could use swiftech mcr320 aka cooltek extream 3...
__________________
Originally Posted by Jimmer411 View Post
Tho personally Iam wishing I had more girth than length. This skinny thing I got just dont get the job done anymore. The wife agrees.
eXa is offline   Reply With Quote
Old 04-18-2006, 06:48 AM   #4
eXa
eXa's Avatar
and i would go for a modified ddc+. when its modified its stronger than the d5.
i like the size of it too!
__________________
Old 04-18-2006, 06:51 AM   #5
nealh
check this mp3 files on the sound of each pump
the D5 sure sounds quieter to me than AQX 50z
http://www.cooling-masters.com/articles-33-14.html
__________________
My Heat
L629F221 e6600 @3600 1.4v D-Tek Fuzion
Badaxe2 bios 2747 rev 505 1.3v vFSB/1.575v MCH
2 x 2GB Corsair XMS@DDR 800 5-5-5-5-18@1.85
x1900xt MCW60
Rad: PA120.3 3YL SL/ Pump: DDC2 w/ Petra's top 7/16in ID masterkleer
Seagate 320gb 7200.10/ 200gb 7200.8 SATA
X-Fi music/SH-203B/H62L/LH-20A1L
Corsair HX620w /Acer AL2223W/modded TJ07
nealh is offline   Reply With Quote
Old 04-18-2006, 06:55 AM   #6
gocchin
Overclocking X.I.P. Otaku
gocchin's Avatar
Get the PRO LE over the SP LE, they are the same block and perform the same except the SP has the brass top and is more expensive. The D5 should be fine with the triple rad... it is a pretty quiet pump from the ones I've tried. My 50z was louder than expected.
gocchin is offline   Reply With Quote
Old 04-18-2006, 06:56 AM   #7
maratus
maratus's Avatar
Radical_53
If it's possible, please record your DDC+ noise!
maratus is offline   Reply With Quote
Old 04-18-2006, 07:25 AM   #8
Radical_53
Radical_53's Avatar
Like a sound file? Well, that could be hard to do. Both pumps are really quiet. If I turn on my PC and have all fans turned off, I can merely hear it.
__________________
Old 04-18-2006, 07:30 AM   #9
nealh
check the link above they have a DDC pump not sure if it is the same as DDC + though
__________________
My Heat
x1900xt MCW60
Old 04-18-2006, 07:49 AM   #10
maratus
maratus's Avatar
I heard those files in review and there was old DDC which is known to be dead silent,
I wonder if there's any difference in noise (timbre ) between 10W (old) and 18W (Plus).
Old 04-18-2006, 07:50 AM   #11
maratus
maratus's Avatar
Hmm, can you compare noise timbre?
P.S. Sorry for double post, smth wrong with Edit
Old 04-18-2006, 07:54 AM   #12
berk
berk's Avatar
That DDC Pro with water tank is gonna be my next purchase...
http://www.liquidluxx.de/cms/artikel...&id=16&seite=3
Dont know any German,but it looks the bollocks.
__________________
I'm just not interested in AMD.
Bugs in sigs suck.
Cheapen SSD drives (we're almost there!!) and bring back mobo fans!!!!
...remember kids,the Ipad is an incredible experience...
berk is offline   Reply With Quote
Old 04-18-2006, 10:07 AM   #13
Radical_53
Radical_53's Avatar
The DDC+ is a little louder. But you can only hear it when the pump is outside the case.
I can hear neither of them when using a plex top, water additive and a thin layer of neoprene to kill vibration.
__________________
Old 04-18-2006, 10:15 AM   #14
JoeBar
Xtreme Mentor
JoeBar's Avatar
Have u tried Nexxxos rads and don't like them? A for the tube i'll go with the tygoon cause i want to order from certain European stores (due to high shipping costs for us orders) and this place has it in a quite decent price.
__________________
Watercooling setup:
Old 04-18-2006, 10:20 AM   #15
eXa
eXa's Avatar
why bother with nexxxus when tests and stuff have shown that there is better rads out there!
__________________
Old 04-18-2006, 10:22 AM   #16
JoeBar
Xtreme Mentor
JoeBar's Avatar
PA 120.3 seems like my favourable option till now. The way i see it i'm going to buy it once and enjoy it for a long time. However will u suggest a 6 fan push/pull config or 3 fans push or pull?
DDC Ultra is indeed a very nice, compact pump with great head (i know how important this is) but can it really surpass D5's double flow rate?
__________________
Watercooling setup:
Old 04-18-2006, 10:26 AM   #17
eXa
eXa's Avatar
3 fans. wont get much lower temps with 6. pa series is made for low cfm.about push\pull, just do whatever fits you best!
edit: and would recomend the yate loon d12-sl12!
a modified ddc ultra would perform as good as if not better than a d5
__________________
Old 04-18-2006, 10:29 AM   #18
JoeBar
Xtreme Mentor
JoeBar's Avatar
Thanks for the info m8!
Due to the fact that i'll be installing the rad outside i have both option available.
What about the pump?
__________________
Watercooling setup:
Old 04-18-2006, 10:32 AM   #19
eXa
eXa's Avatar
well then you can easily check the difference!
__________________
Old 04-18-2006, 10:35 AM   #20
Radical_53
Radical_53's Avatar
Well, I had all the Nexxxos here. Really, don't get them. In Germany they're not even half the price as Black Ice and maybe 1/3 of a Thermochill, still I wouldn't want one for my rig.
Tygon is some very good stuff, but expensive I got my stuff from the UK, should be the same shipping to Greece I guess (EU).
You can get the Yates at ebay, really nice price tag
__________________
Old 04-18-2006, 10:40 AM   #21
JoeBar
Xtreme Mentor
JoeBar's Avatar
I have decided on PA120.3 finally. I'll get some of them (including tygoon) from UK also.
I already have have fans.
My only undecided purchase is the pump. However i just saw that Alphacool has some new laing pumps...
__________________
Watercooling setup:
Old 04-18-2006, 10:46 AM   #22
Radical_53
Radical_53's Avatar
Are the new ones already liste? Their former CEO told me that they'd get some nice new stuff
__________________
Old 04-18-2006, 10:48 AM   #23
JoeBar
Xtreme Mentor
JoeBar's Avatar
Yes they are!
Now it makes the pump choice even harder...
DDC Ultra or the new Laing D5 Vario?
__________________
Watercooling setup:
Old 04-18-2006, 10:52 AM   #24
eXa
eXa's Avatar
could you adjust the speed on the old d5?
__________________
Old 04-18-2006, 10:55 AM   #25
JoeBar
Xtreme Mentor
JoeBar's Avatar
Yes you could with 5 intervals too. Their only diff is that the new one pumps 1500L/H (the "old" one had 1200L/H)!
__________________
Watercooling setup:
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
