The neo2 platinum does that on the older bios.
If you want it to report with *some* accuracy, you'll have to use the latest bios in there.
However, the modded 1.36 I think was the best bios to work with so unless you really care about what the bios tell's you, don't worry about it.
I've had 5 or 6 of those boards on phase. On the older bios, that's what it reads when frozen, 40c.
Cheers
Gray
__________________
Nearly back from the dead.
