XtremeSystems Forums
Go Back   XtremeSystems Forums > Software > Operating Systems > Microsoft Windows
Reply
Old 04-15-2006, 08:02 PM   #1
shaolin95
shaolin95's Avatar
In this age of 2 GIG ram...what will be the best swap file size to use.
I was wondering now that I have 2 GIGs of RAM what swap file size would you recommend.
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
shaolin95 is offline   Reply With Quote
Old 04-15-2006, 10:15 PM   #2
Kobalt
Xtreme Cruncher
Kobalt's Avatar
I recommend setting both the initial and max values at 1.5x the amount of ram you have. If you get "out of memory" errors then increase the maximum to 3x the about of ram you have.
__________________
E6420 :: MSI Neo2-FR :: 4GB OCZ Platinum DDR2-800 :: 8600GT :: OCZ GameXStreme 700w :: Scythe Infinity :: 150GB Raptor and 2x 160GB Drives
Audio: Chaintech AV710 (ASIO out) -> MHDT Constantine DAC -> Darkvoice 336i Tube Amplifier -> HD580s with Cardas
Kobalt is offline   Reply With Quote
Old 04-16-2006, 12:14 AM   #3
shaolin95
shaolin95's Avatar
I dont really believe too much in the 1.5x theory as logic tells you is not really accurate. I mean think about it. If I had 1gig and set it at 1.5 x that equals 1.5gig. Now if I have 2gigs or ram and set it up at 1.5x that equals 3Gigs. So, that means that I should have been having lots of issues when I had 1gig since my swap file was only 1.5gig compared to my new one at 3gigs. It makes no sense at all to increase the swap file when you are actually adding MORE ram to your system. See my point? Logic tells me that if the swap files is there to compensate for the lack of ram that by adding more Ram I will actually need a smaller swap file.
I was actually looking to see what people is using total like say a 4 gig total between ram and swap file or so....
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Old 04-16-2006, 12:21 AM   #4
Heretic
Send a message via AIM to Heretic
My page file is 2gb and I've never had any trouble. You can't really decrease performance by having a larger page file...you'll just decrease the amount of usable hard drive space you have. That said, most people will find that 1-2gb page file will suit them just fine. If you have any real worries about the size, you can set it to some larger value and then monitor page file usage over a couple of days of normal computing. From that, you can find a better size to suit your needs.
__________________
3800 X2 @ 2.7GHz
DFI nf4 SLI-D
2x1gb GSkill ZX
TT Sonic Tower
Visiontek 4850
X-Fi XtremeMusic
Corsair 750TX
Heretic is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
