XtremeSystems Forums
Reply
Old 04-10-2006, 06:12 PM   #1
One_Hertz
One_Hertz's Avatar
Send a message via MSN to One_Hertz
What the heck got borked?
Ok Lately i've been having severe problems with my watercooling setup. The setup is as follows:
BIX3 with 3 38mm 80cfm panaflos
iwaki MD-20-rlzt
Swiftech Strom
Maze 4(in the loop but not hooked up to vcard)
cleaflex 60 tubing
Zerex additive (about 8%)
When I just set it up 4 months ago the temps were just fine with baout 40C load on 130watts or so of heat with an ambient of 25. Now however I cant even run my comp loaded for extended periods of time before my now stock X2 reaching 60C! it's pretty freaking ridiculous because in the first 10 min or so of dual prime95 its floating at around 40C and from then on it just slowly keeps rising up and up to 60 when I shut it off. I've cancelled out a rad problem because as soon as i turn off the prime95 then the cpu goes to like 4C above ambient, which means water isnt getting hot at all. the idle temp is fine as well. I have no idea wtf is happening or how this is happening but it is. It only got this bad after I remounted the last time but before it was pretty bad as well. Although I have no idea what I did wrong with the mounting of the storm and have redone it multiple times with a similar result of slowly rising temps. Anyone have any ideas?
I'm now off to remounting the waterblock again
edit: hmm when I run a single instance of prime the cpu only gets to liek 45C and stays there... By now I am thinking temp sensor?
One_Hertz is offline   Reply With Quote
Old 04-10-2006, 06:17 PM   #2
safan80
Xtreme Guru
safan80's Avatar
when is the last time you (re)applied thermal Grease?
__________________
Watercooling parts:
Pa120.3 rad (CPU)|PA120.3 (for video card)|GTZ on CPU
|stock cooling on chipset|Laing DDC w/ Petra'sTech DDCT-01s Top on cpu loop|aqua extreme 50z pump on gpu l
cpu i7 960 @???
old cpui7 920 3836A762 @ 3.7Ghz
Gigabyte EX58-UD5 F9e bios
12GB of G.skill (6 x 2GB)DDR3 perfect storm F3-16000CL8-2GBPS 7-7-7-21
2x bfg 285
new Dell 30"LCD 3008wfp oh the colors!
LG GGW-H20L
COOLER MASTER Real Power Pro RS-C50-EMBA-D2 1250watt for the cpu/mobo & video
OCZ600MXSP 600W for the hard drives
areca 1280ML with 2GB ecc of cache running in other 16x pci-e slot with battery backup running two raid 10 arrays 2TB boot array 6TB storage
sound card: Auzentech Forte 7.1 | Gigaworks S750 7.1 speakers
OSes: debian Linux unstable, and Windows XP pro x64 w/sp2| testing windows 7 x64 ultimate
safan80 is offline   Reply With Quote
Old 04-10-2006, 06:20 PM   #3
One_Hertz
One_Hertz's Avatar
today
Old 04-10-2006, 06:25 PM   #4
creidiki
Xtreme Guru
creidiki's Avatar
Send a message via AIM to creidiki Send a message via MSN to creidiki Send a message via Yahoo to creidiki
You still have the IHS on? And the pump is working fine yes (silly question with a stormtrooper, but might as well get that out of the way)
__________________
Originally Posted by Bloody_Sorcerer
flowrate is for losers!
Originally Posted by MaxxxRacer
Thermaltake is kind of like AIDS; it won't go away just by ignoring it.
creidiki is offline   Reply With Quote
Old 04-10-2006, 06:36 PM   #5
dnottis
Xtreme Mentor
dnottis's Avatar
Storm is probably plugged.
__________________
Q9550 @ 4.105 Ghz
Gigabyte P45 UD3P F9
G.Skill PC2-8800 DDR2-1100 8GB Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, D-Tek FuZion pro mounted, FuZion GFX 2
Cooler Master UCP 1100 Watt PSU
MSI HD5870 1Ghz (1.16v), 1300Mhz
Lian Li PC V-2000
Acer X222Wbd 22" LCD
3 x WD 640GB WD6400AAKS HD
Pic of my watercooled rig
dnottis is offline   Reply With Quote
Old 04-10-2006, 07:23 PM   #6
creidiki
Xtreme Guru
creidiki's Avatar
Thats the most likely thing, yup.
other things that can cause those symptoms:
your pump dying (an iwaki dying in a pc waterloop, yea, right, pull the other one)
TIM1 (thermal grease between die and IHS) got all squeezed out byt thermal cycles and remountings (extremely unlikely and its far more gradual than this)
__________________
Old 04-10-2006, 11:35 PM   #7
MaxxxRacer
Xtreme X.I.P.
MaxxxRacer's Avatar
Send a message via AIM to MaxxxRacer Send a message via MSN to MaxxxRacer
Possibilties
1. A Clog somewhere
2. A Bad Mount of the CPU Waterblock
3. Your Pump is Dying. (but highly unlikely)
4. Your Onboard sensors have gone crazy
A comment on #4. On my Abit 939 testbed, the mobo reads the CPU temp as 70C at load (its not), so its possible that the motherboard or on die sensor flew over the cookoos nest.
MaxxxRacer is offline   Reply With Quote
Old 04-11-2006, 02:44 AM   #8
KaptCrunch
Banned
or your PSU is failing underload.
KaptCrunch is offline   Reply With Quote
Old 04-11-2006, 04:01 AM   #9
One_Hertz
One_Hertz's Avatar
My psu is PC P&C 510 deluxe and I really doubt its maxed out, so yeah most likely a clog in the storm. I reseated the block 3 times with very similar results so thats most likely not the problem here as well. I doubt my pump is not working properly because I clearly see the water level in the tline rise substantially when i turn it on and stay high while the pump is working, which means there is a constant increased pressure within the loop. I guess I'll be flushing the system this weekend. Thx for the help.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
