XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 04-10-2006, 05:48 PM   #1
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Insulation
So I read the insulation topic and I still have a few questions, well actually I have one question, but I know there will be more. My questions will all be dealing w/ an A64 and s939 board.
Question 1:
I would like to avoid packing my socket full of grease so I was wondering if putting a sealing "wall" of grease around the edge of the socket but not all over the pins would be a good enough barrier to moisture? Is it neccessary to pack the pins, besides being messy, it looks gross, even if it'll be under inches of insulation.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 04-10-2006, 05:49 PM   #2
n00b 0f l337
I am Xtreme
n00b 0f l337's Avatar
Send a message via MSN to n00b 0f l337
Its not all about sealing moisture out, your also sealing the moisture in. Theres already air there.
For 24/7, get a bit of di-electric grease in there.
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
n00b 0f l337 is offline   Reply With Quote
Old 04-10-2006, 07:33 PM   #3
epion2985
Xtreme Mentor
epion2985's Avatar
What he said, dont gamble, unlese you have money comming out of your rear. Ever seen someone pop off their evap and find the pins on the cpu rusted clean off
__________________
French Duron Poof
Every time you lap a swiftech block a kitten dies
"Extreme Systems, yes. But it could also mean Extremely creative, Extremely resourceful and on and on. Please don't use the name of this site as an excuse to do stupid things" -situman
HEAT
epion2985 is offline   Reply With Quote
Old 04-10-2006, 10:21 PM   #4
[XC] gomeler
*grumble* ok, good point =) Grease it is.
__________________
Old 04-11-2006, 06:03 AM   #5
Levish
Send a message via AIM to Levish Send a message via MSN to Levish
would electrical contact cleaner work to blast away grease in a socket?
__________________
i7 @ 4000mhz 1.25vcore | Evga x58 | OCZ Gold 3x2GB | Powercolor HD4890
Levish is offline   Reply With Quote
Old 04-11-2006, 12:46 PM   #6
[XC] gomeler
Yes, so I've heard it easily removes the grease, but it just seems like such a mess. Just lacquered all the voltage regulators on my A64 and just resealed it with some ceramique on the chip. My next question, how far around the socket should I insulate? I was thinking 2-3" of solid closed-cell foam should provide enough insulation, with the backplate getting a thinner layer so it'll fit in my case. I looked at the A64 insulating guide and they don't insulate the whole board.
__________________
Old 04-11-2006, 12:54 PM   #7
[XC] gomeler
One other question, are there any components that are situated around the socket that would object to a layer of sealant? Someone once mentioned a clock generator as being something I wouldn't want to cover up?
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
