03-28-2006, 03:50 PM
#1
XIP
TeamXtreem PC4000 Cronus (-5B F) - Let's see your Infineon chips do this!
http://www.hl2online.com/images/10x275_cronus2gb.JPG
These sticks just love the tight timings and as such I love them.
Seriously, have you ever seen micron this tight at these frequencies? Sticks running fully stable with 2.8v, cpu is an opty 146.
Reason: Big a$$ screenshot - use URL tags, please!
03-28-2006, 04:18 PM
#2
XS_THE_MACHINE
Very nice :thumbup: You might want to test out where gains from tight timings end though, ie sometimes trc/trfc 7/12 may be too tight and you'd get better performance at say 9/15. Either way, those timings are impressive.. lets hope the team infineon I get tomorrow does that well
__________________
Rig #1 | Opteron 165 (2898 @ 1.35v) | DFI nF4 Ultra-D | GSkill ZX 2x1GB | HIS X1900XT 512MB | Seasonic S12 550w in Antec P160
http://www.last.fm/user/repoman0/
03-28-2006, 04:27 PM
#3
XIP
These are just perfect. At these speeds TRTW of 2 is "too tight" and actually lowers scores and stability. But everything else I've set here is great.
This is Micron btw, but it looks as tight as a lot of Infineon.
03-28-2006, 06:36 PM
#4
Muslim Overclocker
How about some 3D
Also I will mention a trfc of 12 won't be stable at all for you. Thats way too low for this timing...
__________________
My watercooling experience
Water
Scythe Gentle Typhoons 120mm 1850RPM
Thermochill PA120.3 Radiator
Enzotech Sapphire Rev.A CPU Block
Laing DDC 3.2
XSPC Dual Pump Reservoir
Primochill Pro LRT Red 1/2"
Bitspower fittings + water temp sensor
Rig
E8400 | 4GB HyperX PC8500 | Corsair HX620W | ATI HD4870 512MB
I see what I see, and you see what you see. I can't make you see what I see, but I can tell you what I see is not what you see. Truth is, we see what we want to see, and what we want to see is what those around us see. And what we don't see is... well, conspiracies.
03-28-2006, 09:30 PM
#5
Out of curiosity, DS/DDS? Thanks!
__________________
03-28-2006, 10:09 PM
#6
if that is infineon show me a 3D bench at those frequenties
__________________
Gigabyte P35C-DS3--E6600 L628B123--2x1GB Gskill Pc6400HZ+1GB D9GMH OEM--Sapphire x1900XTX--Tagan 580w--GFX Watercooled--Cpu Cooled By Mach2 GT modded by Jort
03-28-2006, 10:16 PM
#7
I am Xtreme
its micron -5bf
03-28-2006, 10:31 PM
#8
No rest for the weary
Originally Posted by Revv23
its micron -5bf
hehe then show it to me 3 months from now if it isn't in rma
__________________
heatware chew*
AMD is Back in Black Lifes more fun at -190C
How To Behave On An Internet Forum
http://www.thewavingcat.com/2008/02/...eed-the-troll/
http://www.livestream.com/chewsdisasterarea
Originally Posted by Sampsa
1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
03-28-2006, 10:47 PM
#9
Memory Addict
woah could you have an even larger screenie... crop and resize my friend
infineon hmmm - straight from bios set timings you see.. a64tweaker only used to display what was set in bios
Dual stressprime large FFTs with 890MB allocated to each instance
Idle and Load
It's shame infineon chips these days aren't as good as the first batch though
03-28-2006, 11:36 PM
#10
Corsair Engineering
Originally Posted by EnJoY
It really depends if there is anything else these can do besides 1M. There is quite a few Infineon Rev.C kits than could pull that off and @ 5- 2-3-3.0. I have one here that can do 32M @ 278Mhz and all 3D one wants at 272Mhz.
So, you need to show us something more, please  BTW, I changed IMG tags toi URL in your 1st post...
__________________
3ch 3x2GB WR - Dominator 2000C7GT @ DDR3-2560 7-8-7-20
03-29-2006, 11:20 AM
#11
XIP
For the last time, THIS IS MICRON -5B F!
They are totally 32m stable, but won't run COD2 for longer than 15mins without crashing to desktop. Sadly I can't do anymore testing for now as a fan next to the mobo on my test bench was knocked over and chopped off the power switch and possibly a cap. I'm ordering a new board overnight so I can have it when my dualcore arrives tomorrow.
03-29-2006, 11:39 AM
#12
Love and Peace!
5b F should have a pretty long lifespan. been using mine for almost 4 months now, no signs of slowdowns yet
enjoy, looks like you got a pretty good set  i'm assuming you actively cool ram as well?
also, lets hope your new board does for you what my new board did for me
__________________
Got a fan over those memory sticks? No? Well get to it before you kill them
03-29-2006, 11:57 AM
#13
Banned
ok, from my perspective and has been playing the 5b-f on the 9~11 multiplier restricted CPU such as Opteron or a64, if you do the divider, the stability and overclock on 5b-f decreases like nowhere ; however, insteresting enough, if you have fx series(at least 57 or even 60), try running upper divider like 216mhz, 233mhz, 250mhz, then you will be amazed by how tight and strong your 5bf can go. be aware of this.
03-29-2006, 12:14 PM
#14
Love and Peace!
i noticed this earlier, back when i was using the 704 bios with the >1:1 ratios, setting it to 233mhz got me a bit extra. i should really try that again
__________________
03-29-2006, 12:25 PM
#15
XS_THE_MACHINE
my 4 month old -5B D did and still does this link
almost as tight, and 290mhz... at only 2,7v
hehe almost forgot, great result enjoy ... good to see -5B F pulling off, and we havent even heard about one dead stick yet, have we?
__________________
Intel Conroe E6400 - Intel P965 - 4GB DDR2 - 8800GTX - 320GB Western Digital - Dell 2007WFP - Windows Vista Ultimate
03-29-2006, 12:52 PM
#16
But lots of unsatisfied customers.
Great results man, hope you get it completely stable (and even higher if possible  )
__________________
Zotac 790i Ultra Supreme
Q9550 E0 4.05 ghz@1.24v under OCZ Vendetta 2
2x Evga 9600GT SSC SLI
OCZ OCZ3P16002GK 1333 @ 7-7-7-20 1T 1.5v
Corsair VX550w, Ghettoed Antec Super Lanboy
03-29-2006, 12:59 PM
#17
Xtreme Cruncher
03-29-2006, 01:35 PM
#18
XIP
Believe it or not guys I'm actually selling this set now. I need to fund the new mobo, so it was either these or the new Ballistix set I have. The ballistix aren't quite as tight but clock a bit better, however these guys were substantially easier to overclock.
03-29-2006, 11:27 PM
#19
looks like you got the pick of the litter!
my cronus microns won't even boot at 9x250 with 2.5-4-4-8
...even though that's the SPD rating
...which apparently was some sort of mistake.
__________________
Opteron 165 @ 2.6 (9x289, 1.425v) + SI-120 w/ 120x38mm Delta Tri-Blade High Speed
DFI LanParty nf4 Ultra-D (bios 1114) * 2x1Gb Team Cronus (3-3-3-8, 1T)
Leadtek PX6800GT TDH (400/1100) * Hitachi T7K250 SATA II 250Gb
Sunbeam NUUO 550W * Cooler Master Stacker
03-30-2006, 02:37 AM
#20
Ya, the true rating is 3-3-3-8. Apparantly, they used the programming from another set as a template and never bothered to change it from 2.5-3-3-8 to rated 3-3-3-8 (or something like that, I just know they never bothered to reprogram something)
__________________
03-30-2006, 09:28 AM
#21
i hadnt heard 2.5- 3- 3- 8 box mine came in said 3.0 -3- 3- 8
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
