03-09-2006, 10:45 AM
#1
Each core can finish SuperPi32MB individually but not at the same time Opty165...why?
Hi!
I am just beggining my OCing with dual core and hav my Opteron 165 at 2750MHZ with 1.50vcore. Why is it that when I run SuperPi 32mb dual one of my core fails but if I try each core separately they both pass the test? Does that mean there is a problem with dual superpis as Ive been reading?
I am using a dfi nf4 Ultra-d with the latest Tony bios 704-2 (something like that). All voltages are fine (multimeter tested).
Regards
PS I am working on my new sig but just replace the CPU, video card, and mobo with the Opty 165, dfi nf4 ultra-d and xfx 7800gtx oc.
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
03-09-2006, 10:55 AM
#2
OCZ Memory Guru
Make 2 folders.....SuperPi will try and write the output file to the same file and it fails.
2 folders, 2 exe's...name them 1 and 2 or something..then open each, go into task manager and set the affinity...then fire away
03-09-2006, 11:12 AM
#3
yes I did that and still. I mean I can do it with 1mb or smaller runs with both cores but when I try 32MB one core usually fails but individually they pass it all the time.... strange. Maybe memory related?
Do you think this test is a good one:
core 0 looping 3dmark 2001 in software rendering
core 1 superpi 32mb
Will thar work and take anu superpi "issues" out of the equation? Perhaps a better one will be
core 0 pcmark 2004
core 1 pcmark 2005
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
03-09-2006, 11:58 AM
#4
Maybe heat problem? What's your CPU and PWMIC temp? when running dual superpi?
__________________
Opteron 165 0550UPMW 300x9=2700Mhz (vcore=1.35v in BIOS)
DFI NF4 UT Ultra-D (04/06/2006)
PQI Turbo 3200-2048DB @207Mhz(7/10) 3-3-3-6
Antec TP-II 550w PSU
VisionTek X800 128MB @440/420
Cooler Master AMMO 533
Windows XP pro SP2
03-09-2006, 12:11 PM
#5
Not even 38C at load ofr CPU...Ninja rocks :-) PWMIC is low as well.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
03-09-2006, 12:56 PM
#6
Memory Addict
one of the pains of dual core figuring dual pi stability
things to test and try
1. increase vcore incrementally by 0.05v if you can and retest
2. play with drive/drive data strength combinations
3. play with TREF values
4. play with vdimm
keep at it.. retesting every combination you may need to reboot and test all combos several dozen times
but all worth it
03-09-2006, 08:43 PM
#7
I am just right into 5 hours 30 mins of SP2400 dual at full %100 load and no problems... Is SP2004 any good?
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
03-09-2006, 09:40 PM
#8
Wich test in SP2004?
__________________
Q6600 rig coming soon....
03-09-2006, 10:00 PM
#9
Stress CPU test as I am trying to avoid my memory untill I get the OCZ booster. Is that mistake?
UPDATE:
I just decided to run custom and set 400MB for each SP2004 since I have 1GB total ram and its been an hour and so far so good I am not to sure if I am using a bad program or I am not that far from been stable.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
03-09-2006, 11:02 PM
#10
Xtreme Guru
Overheating?
__________________
i5 750 4.20 GHz @ NH-D14 | 4GB | P7P55D LE | 8800 Ultra | OCZ Agility | CM750W | HAF922
Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
Originally Posted by CompGeek
The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
03-09-2006, 11:13 PM
#11
Right now I am running full %100 stress with SP2004 and my temps are:
CPU 35ºC
PWMIC 29ºC
Chipset 32ºC
Trust me, my rig doesnt sound like a vacumm cleaner for nothing :-) Its really cold and as high end as air can be IMHO.
PS Nice overclocks on your sig :-)
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
03-09-2006, 11:17 PM
#12
Xtreme Guru
shaolin95
Dual prime 35C? Thanks
__________________
03-09-2006, 11:20 PM
#13
Admin
Ever thought that it's unstable at that speed (in the classical sense--it's obviously unstable because it fails, but classical in that it fails because their are either too little potential or too much heat)? Core x can't remain stable because the other one is reducing the cooler's capabilities of removing heat from core x. Or heat isn't necessarily getting in the way and it just needs more volts to keep signal strength up.
Ivan...35C is possible with ~18C air on great aircooling. And judging by those PWMIC and chipset temps, 18C also seems logical.
EDIT: I'd like to clarify....adding heat when the voltage is only barely enough can cause a proc to be unstable....the added heat is coming from loading the other core simultaneously.
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
03-09-2006, 11:34 PM
#14
Ivan I can take a pic of my SP2004, task manager showing %100 plus, Smart Guardian to show my temps but honest, why would I even be lying about my temps? What will be the point? I will take the screenshot anyway....
Keep in mind that Utah is fairly cold these days, I have open window, and its a Scythe Ninja WITH a big delta fan @ 150+ CFM.
As I said the highest temp Ive seen its 38ºC and thats without been even close to the 200 hours of "cure" time for AS5. This has been my best ninja install ever...went really smooth and working great as you can see.
If needed...do you think it will be safe to add a little more vcore since I have low temps or should I just be happy with my OC?
Regards
PS Gonna get my room thermometer later to add the very important room temp to my post. BTW my current idle is CPU 22C , PWMIC 22C, Chipset 32C.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
03-10-2006, 01:54 AM
#15
I've had this same problem for months and still have it, I do run 2 lots of Prime 96 but for the hell of it I cannot make the super pi run both at the same time.
Here's what I did I made 2 folders both on the desktop then donloaded a super pi into each folder then unxipped to the same folder then renamed the first to super pi 1 then the second to super pi 2, I then open each and go into task manager set the affinity super pi one to core 0 and super pi 2 to core 1.
As soon as I then try to run both at the same time I get not convergent in SQR05 every time.
This maybe is due to the way I'm naming it? In Prime you go to name it differently I think that could be the problem can you do a step by step guide like the one for Prime as I'm sure I'm missing something simple.
Incidentally doesn't matter what PC I've ever tried it on and I have tried many times I always get the same result, overclocked std or even underclocked, what I'm trying to say is that it has to be the way I'm telling it to do run the programme it's definately not an unstable PC.
Any help would be appreciated this really does do my head in every time I try it.
THANKS
__________________
Silverstone TJ07
i7 920
EVGA X58
Corsair Dominator 6gb 1600GT 2000MHz 8-8-8-20
Thermochill PA120.3
Big NG fan controller
Heat Killer v3 CPU Acetal
EK Full block GPU
ATI 5870
Corsair HX850
1X 1TB Samsung
1X 500GB Seagate
1X Crucial SSD 64GB OS
03-10-2006, 02:01 AM
#16
I just finished superpi32MB at 2731MHZ so my theory is that since the temps are low, individually each core can finish it at 2751mhz...I will think that vcore is indeed what is preventing both cores to do it at 2751mhz.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
03-10-2006, 04:12 AM
#17
Originally Posted by IvanAndreevich
shaolin95
I have never had any of the dc optys I've had do under 40c on a TT BT air.
This new 3800 I have is the coolest running dc I've had.
Room temp was 72F
03-10-2006, 04:15 AM
#18
Admin
His idle temps are 22C on the CPU and the PWMIC....ambient is in the teens at the highest. Also doesn't sound like the ninja is that great at keep load temps down, I thought it was better
__________________
03-10-2006, 07:41 AM
#19
Originally Posted by shaolin95
Hi!
Regards
I would suspect "Power supply" or power your rails to be more specific.
Both cores could draw more power and your PSU /mobo may not be able to provide a stable current.
03-10-2006, 08:32 AM
#20
Memory Addict
if you can dual prime but not dual 32m then it's your memory timings and settings as originally stated - remember AMD64 and it's memory controller are all in one...
03-10-2006, 09:20 AM
#21
I checked with my multimeter and rails are doing great. I just added from 1.5 to 1.525 and see what happens. 1.55 is the highest Ishould go on air right?
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
03-10-2006, 09:29 AM
#22
Nah, as long as your temps are good, you can go as high as you want with volts (well, not really, but if you stay under 1.8v you'll be ok with that good a aircooling  )
03-10-2006, 10:01 AM
#23
WOW I wouldnt give 1.8 to my old Newcastle much less to this one :-). I am thinking 1.55v as my limits since I dont want to kill it and 2730 (seems to be doing good with 2750mhz right now) is enough from a 1.8 CPU. Maybe 1.6 if it really gives me a lot of MHZ more.
UPDATE:
Room temp is 60ºF
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
03-10-2006, 10:14 AM
#24
this is what im thinking too. the 2 instances of superpi will still be using the same memory controller. obviously 2 instances are going to strain that controller more than the one would and this could explain the failing you see when running both at the same time.
03-10-2006, 10:28 AM
#25
It seems the extra vcore did the trick now I ran superpi 32mb perfectly at 2751MHZ. I notice that Smart Guardian says 1.48vcore.
Well, gonna go for more and see what happens but I am already a happy camper. :-)
PS
Just passed SuperPi32MB with single cores at 2806mhz but not with both. I was able to do SuperPI 1MB with both at that speed.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
