XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 03-07-2006, 11:15 AM   #1
Gray Mole
Gray Mole's Avatar
Lightbulb Kayl / 2 = SLI
I got asked to try something for a guy here in the UK, who will remain nameless unless he chimes in.
He wanted me to have a go at making some decent thin evaps for his sli kit he's going to make.
So he sends me a Kayl old revision head, and I say...
No problem
So the only real challenge is filling the captube hole and pounding in the tube just a little on the top of one, and the bottom of the other, so that it will braze up nice. The tiny 'dot' of braze where the cap hole is shouldn't make any real difference and will likely not even see much of the contact patch.
I had to cover the old top section's hole at the top, that's the brazed square up there. I also cut the top of the base section for better refirgerant flow.
That's a 1/4" suction, which is a little restrictive, but shouldn't hinder performance that much.
It's only got the 2 channels, but that should allow for decent surface area. I think it will work better than people will think it should, but they are thin enough to fit nicely no matter what setup you have.
Captube will be 3.5m of .031" on each line, entering just under the suction tube which will flow up the channel opposite.
I'm just waiting for the suction flexi to get here, and I'm out of captube, so will pick some up tomorrow and braze it up in preparation for the flexi's.
Sorry for the delay, I finally got the 1/4" bore flexi SS line, and brazed and finished things off.
10' of .028" captube per head. 600mm flex per line. 1" tail of 1/4" pipe from the heads to the flexi.
Who says phase can't be sexy
Cheers
Gray
__________________
Nearly back from the dead.
Gray Mole is offline   Reply With Quote
Old 03-07-2006, 11:23 AM   #2
Gray Mole
Gray Mole's Avatar
Original height vs. sli head. Overall height is 17mm on the taller one incl. cap brazed on, original is 32mm.
Gray
__________________
Old 03-07-2006, 11:30 AM   #3
boardy
boardy's Avatar
Send a message via MSN to boardy
Awwww they look so cute
Boardy
__________________
Bench rig - Asus P5B "Vanilla" / TeamXtreem PC6400 / Q6600 G0 SLACR (Thanks to my fiancee, Steph) / Xclio 750w PSU / Various GFX
24/7 rig(s) - Intel MacBook / Dell XPS M1710
Heatware link CLICK ON ME
boardy is offline   Reply With Quote
Old 03-07-2006, 11:31 AM   #4
unclean
unclean's Avatar
Looking sweet mate
__________________
X2 4200+ @ 2.9GHz + PCI FX5200 + 2 x 512mb Ballistix + SLi-DR + Tagan 530W + Custom Chilly1 evap/R402A phase unit by Gray on the way + 2 x 120GB RAID0 Barracudas + Adaptec SA2610 controller w/4 x 250GB Hitachi deskstars in RAID5 + DD TDX watercooling || Dual XP-M 2500+ @ 2.45GHz + 2GB PC2100 + Asus A7M266-D + DD TDX watercooling + Dell PERC (AMI) SCSI UW RAID5 w/9 x 18.2GB 10k discs || Dual Athlon MP1900 + 1024mb PC2100 Crucial ECC reg + 40GB Maxtor || Dual Celeron 366 @ 550MHz + Abit BP6 + 512mb PC133 || Dual P3 1GHz + Epox EP-D3VA + 4 x 512mb PC133
unclean is offline   Reply With Quote
Old 03-07-2006, 11:46 AM   #5
Ssilencer
Ssilencer's Avatar
Send a message via ICQ to Ssilencer Send a message via MSN to Ssilencer
Nice work gray!
Ssilencer is offline   Reply With Quote
Old 03-07-2006, 11:53 AM   #6
[XC] mysticmerlin
Xtreme Cruncher
[XC] mysticmerlin's Avatar
Looking good so far.
__________________
[XC] mysticmerlin is offline   Reply With Quote
Old 03-07-2006, 12:54 PM   #7
expansionvalve
tasty
expansionvalve is offline   Reply With Quote
Old 03-07-2006, 01:18 PM   #8
fatty
-100C Club
fatty's Avatar
Send a message via MSN to fatty
Hope your charging like a wounded bull mate
__________________
Originally Posted by s7e9h3n
Hell, if it would unlock this godly 154, I'd put on a tutu and dance around like a ballerina
Mach 2 Problems Click
My Work
fatty is offline   Reply With Quote
Old 03-07-2006, 01:44 PM   #9
MeltedDuron
Dothan FTW!
MeltedDuron's Avatar
Send a message via AIM to MeltedDuron Send a message via MSN to MeltedDuron Send a message via Yahoo to MeltedDuron
they're so cuet
__________________
.:Melted's Hardware:.
.:My Workstation::Sorta Done:.
.:Intel E4300@3ghz(375*8):2gb G.Skill HZ 6400@500mhz:Sapphire X1950pro:Gigabyte GA-G33M-DS2R:550w FSP Blue Storm:80gb and 160gb WD SATA2:Cheap MATX Case:.
.:Panasonic Toughbook CF-T2:.
.:Pentium M 753 (900mhz ULV):256MB:40GB:12.1" Touchscreen:. .:Not too shabby for a 2.4lbs of pwn:.
I've been using Intel ever since AMD put an end to my socket A fun. I was almost going to go back when I saw the cheap AM2 chips, but they suck Viva La Chipzilla!
MeltedDuron is offline   Reply With Quote
Old 03-07-2006, 01:56 PM   #10
runmc
Admin
runmc's Avatar
Good job - should work nicely
__________________
Worthy is the Lamb
runmc is online now   Reply With Quote
Old 03-07-2006, 02:00 PM   #11
LukeXE
-130C Club Member
Send a message via AIM to LukeXE Send a message via MSN to LukeXE
I like it !
LukeXE is offline   Reply With Quote
Old 03-07-2006, 04:19 PM   #12
SoddemFX
SoddemFX's Avatar
Nice Grey
Tom
__________________
"What will become of us, will we evolve"
SoddemFX is offline   Reply With Quote
Old 03-07-2006, 04:37 PM   #13
wdrzal
I am Xtreme
wdrzal's Avatar
good work.!!!!!!
keep the 1/4" peice as short as possible, but that small peice won''t hurt performance ,gas will just flow faster thru the smaller diameter. Just so its not real long, flow is greatly reduced at low pressures and small diameters in long runs.
if you don't want to elimanate the thickness of the patch next time, simply thread hole and insert a brass or copper set screw a little below flush and braze over then lap. perfectly flush. more work though.
wdrzal is offline   Reply With Quote
Old 03-07-2006, 04:50 PM   #14
Gray Mole
Gray Mole's Avatar
Thanks everyone
Hey Walt! Yeah I'll be trimming back as far as I dare with the 1/4" to the flex line when it get's here.
With the evaps being so thin to begin with, space wasn't really much of a concern. Beyond that, the mass of the one evap was slightly higher than the other. I know that a brazed on piece isn't going to do a lot for it as it's not part of the whole, but the weight is very closely matched now.
It's just a shame, this will be assembled and then sent away for someone else to play with. I might just try something similar though now for a new project when time allows
Gray
__________________
Old 03-07-2006, 05:20 PM   #15
wdrzal
I am Xtreme
wdrzal's Avatar
I would have probably made 1 with the suction on the bottom and 1 on top to test against each other. refrigerant isn't at its coldest as soon as it exits the cap tube. the rapidily expanding refrigerant causes the area immediatly after the exit of cap tube to have a slightly higher pressure than farther away.
Old 03-07-2006, 06:41 PM   #16
kayl
-100C Club Member
kayl's Avatar
Send a message via MSN to kayl
Originally Posted by Gray Mole
Thanks everyone
Gray
Thats some nice work their garry, copper isnt the best metal to mod
I am interested to see how the 2 layers go their garry.
Ya should be getting some 3 layer ones soon so can see which is better for me
Im interested how you insulate these things.
__________________
GIG X58-UD5, i7 960 5535 i7950 5352Mhz E8600 6300Mhz
Kayl Block Frozen SS systems
Cascade CPU/GPU Tubes
kayl is offline   Reply With Quote
Old 03-08-2006, 12:20 AM   #17
boardy
boardy's Avatar
Gray is there a spare evap now? From what I remember I think there's one. Feel free to cut that one up or I can send you 2 SLI blocks when I get them in off Kayl
By the way guys these will be built into my 24/7 rig using a GL9 1/4hp? compressor under my CPU phase.
Insulating is gonna be the hardest bit but I'm thinking of a pelt type insulation as these things are so small. When I gave the blocks to Gray for modding I had no idea how small he'd make them. Definately smaller than I thought.
Cheers Gray mate
Boardy
__________________
Old 03-09-2006, 07:36 AM   #18
Gray Mole
Gray Mole's Avatar
Well I still have no small suction lines yet but I've brazed up the SLI heads, ready for when they show. will be trimming the pipes down as much as I can for the suctions to be closer to the heads, and cut down on resistance in the 1/4" pipes.
Each head has exactly 10' of .028" captube, so tuning is up to 150w per head max.
And that's that really. You can see the 'dot' on the last one, that's where the captub hole was predrilled, but otherwise prety standard. I've oly done a basic lap on these, will do the full polish after the flexi's are brazed on.
Gray
__________________
Old 03-18-2006, 03:51 PM   #19
Gray Mole
Gray Mole's Avatar
Updated first post with finished lines
Gray
__________________
Old 03-18-2006, 04:11 PM   #20
Marvin
Marvin's Avatar
nice....
__________________
Q9550 EO @ 4.1
Asus P5Q Deluxe
4 Gb DDR2 Gskill
2xVelociraptors 300 gb Raid 0
Sapphire Vapor 4870 1Gb
PCP&C 750w silencer psu
Marvin is online now   Reply With Quote
Old 03-18-2006, 04:23 PM   #21
ayrtonsenna
very nice work there gray, is there much call for gpu evaps?. if there is i will turn some for people to try them.
ayrtonsenna is offline   Reply With Quote
Old 03-18-2006, 04:29 PM   #22
predator500
Very nice can not wait to see how they do
predator500 is offline   Reply With Quote
Old 03-18-2006, 04:50 PM   #23
SoddemFX
SoddemFX's Avatar
Very nice work Gray, they do look a charm
Tom
__________________
Old 03-18-2006, 08:37 PM   #24
Ssilencer
Ssilencer's Avatar
Hey, they look awesome!!
Is that white heat shrink? I really like it!
Old 03-19-2006, 04:15 AM   #25
Comp-Freak
Comp-Freak's Avatar
I think it's white (teflon?) tape.
__________________
Comp-Freak is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
