XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 02-16-2006, 05:42 PM   #1
ProphetX
ProphetX's Avatar
Send a message via MSN to ProphetX
Everyone take this Photoshop test and post your times!
Using Photoshop CS or CS2 (or PS 7)
1.) Download the test image from http://www.quicklance.com/test.jpg
2.) Save it to the computer and then open it up in Photoshop
3.) From there please apply a 'radial blur' with the settings at:
Amount = 100
Blur Method = Spin
Quality = Best
Using a stop watch / ps timer see how long it takes to apply this filter
I just want to see what these new cpu's can really do.
Please list your cpu details, amount of ram and the time it took for the test, just so we can get an idea of how the different cpu's handle this task.
* test adapted from a different forum *
My results are 46 sec completly stock with the system in my sig
ProphetX is offline   Reply With Quote
Old 02-16-2006, 05:50 PM   #2
ProphetX
ProphetX's Avatar
I would really like to see some results from overclocked and stock fx60's
Old 02-16-2006, 05:57 PM   #3
brickout
brickout's Avatar
1:28
Dothan 760 @ stock, 1GB ddr2 533
__________________
e4300 1.8@3.3/2x1GB Corsair XMS2/7800gt/Antec P150/NeoHE 430
brickout is offline   Reply With Quote
Old 02-16-2006, 05:59 PM   #4
ProphetX
ProphetX's Avatar
nice edited with my results........lets keep em comin
Old 02-16-2006, 06:07 PM   #5
Vapor
Admin
Vapor's Avatar
4400+ @ 250x11 (2750)
2x1GB @ 250MHz 3-4-3-1 1T (tight secondary timings, fwiw)
32.58 seconds
EDIT: IIRC, there's a benchmark put out there by DriverHeaven that tests A LOT of different filters....I recommend trying that as a benchmark to get a better idea which system would be best when OC'd (or I can tell you--955XE will win in the end, LOL).
EDIT2: ummm, anybody observe what that looks liek AFTER the effect?
EDIT3: new score coming up....realized my memory was still in the 1:2 divider from a few days ago.....LOL
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline   Reply With Quote
Old 02-16-2006, 06:36 PM   #6
aiya_au
aiya_au's Avatar
30.61secs, my system specs are in my sig
__________________
CPU Intel E8400 4.3ghz (9x478), Poseidon WCL-04 Water Cooling | RAM Crucial Ballistix Tracer PC2-8500 2x1gb | Motherboard Asus P5Q Deluxe | Graphics Card 512mb ASUS 9800GTX+ | Audio X-Fi XtremeMusic, Logitech Z-2300 | Power Supply Corsair HX620 | Case Antec 900 | Input Devices Razer ProClick, Logitech G15 | Display Device Dell UltraSharp 2408WFP, Samsung 226BW
aiya_au is offline   Reply With Quote
Old 02-16-2006, 07:04 PM   #7
Kris
Kris's Avatar
Send a message via AIM to Kris Send a message via Yahoo to Kris
roughly 30secs
__________________
Q9550@3700
OCZ SLI PC2 8500
DFI LP-UT P45 TR2
4670 1gig
antec 650 psu
1-250 gig seagate perp os
1-750 gig perp storage drive
Kris is offline   Reply With Quote
Old 02-16-2006, 07:20 PM   #8
FragTek
Banned
FragTek's Avatar
Send a message via ICQ to FragTek Send a message via AIM to FragTek Send a message via MSN to FragTek Send a message via Yahoo to FragTek
29.45 on Opty 180 @ 2.9ghz.
FragTek is offline   Reply With Quote
Old 02-16-2006, 08:34 PM   #9
Vapor
Admin
Vapor's Avatar
New time....264x11 (2900MHz) for my 4400+ gave me just over 27sec.
Everything else is the same as before, except now my memory is also up to speed
(and I OC'd it)
__________________
Old 02-16-2006, 11:17 PM   #10
IvanAndreevich
Xtreme Guru
IvanAndreevich's Avatar
Send a message via MSN to IvanAndreevich
What's the minimum amount of RAM required for this without swapping occuring?
29 seconds or so
__________________
i5 750 4.20 GHz @ NH-D14 | 4GB | P7P55D LE | 8800 Ultra | OCZ Agility | CM750W | HAF922
Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
Originally Posted by CompGeek
The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
IvanAndreevich is offline   Reply With Quote
Old 02-17-2006, 02:35 AM   #11
Vapor
Admin
Vapor's Avatar
Depends on your Photoshop settings....120MB allotted should be way more than sufficient with this image and filter set (only having one filter helps).
Default allocation is 55% of total RAM.
__________________
Old 02-17-2006, 02:44 AM   #12
fatty
-100C Club
fatty's Avatar
Send a message via MSN to fatty
custom pc's benchmark uses a lot of photoshop stuff
http://www.custompc.co.uk/ under cpc benchmark
__________________
Originally Posted by s7e9h3n
Hell, if it would unlock this godly 154, I'd put on a tutu and dance around like a ballerina
Mach 2 Problems Click
My Work
fatty is offline   Reply With Quote
Old 02-17-2006, 02:53 AM   #13
funkflix
Xtreme 3DTeam Member
funkflix's Avatar
Send a message via ICQ to funkflix
Hmm.. 1.05min with 3150MHz, and PS 7.0! A little bit much i think?
__________________
PC : Gigabyte EP45-Extreme + Intel Core 2 Quad Q9550 + Powercolor HD5770 + 2x2GB PC8500 Chaintech Apogee GT + Creative X-Fi Xtreme Music + Scythe Mugen 2.
Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
funkflix is offline   Reply With Quote
Old 02-17-2006, 07:29 AM   #14
IYP
Send a message via AIM to IYP
about four mins on a PPC 1.67ghz powerbook with a gig of ram photoshop CS
(counting in my head and extapolating after 1/4 of the way cuz i got bored
just woke up and there is no way im geting up and booting my main rig to do this
looks kinda like an abstract buthole if you ask me
__________________
afireinside on AIM :: I just about got walked in on because my mom wanted to show me her website :|
IYP :: hahaha
afireinside :: friggin ruined my night
VOTE YES FOR A MOBILE PHONE SECTION HERE
Need a new screen? Go to THE LCD BUYERS GUIDE
IYP is offline   Reply With Quote
Old 02-17-2006, 11:31 AM   #15
[timko]
[timko]'s Avatar
I get 26.2 seconds with my Opt 170 @ 2.8Ghz 2Gb with Photoshop CS2.
...and for fun...
Mac Mini 1.42Ghz 1Gb -> CSv1 2mins 10sec
Sony Vaio P3-866Mhz 512Mb -> CS2 4mins 57sec
(...that's one fugged up horse after running it thru the filter )
__________________
[timko] is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
