XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 02-15-2006, 12:03 PM   #1
shaolin95
shaolin95's Avatar
OC masters help me solve this weird issue with my dfi nf3. Keeps dying on me.
Hi!
Ok here is the story. Got a DFI NF3 for a long time and it was great. When up to 300FSB ocing my XBLs. Then moved to BH5 (OCZ 4000) got a new Powerstream 520 and a scythe Ninja. Things got even better! Then one day, I got this long beep loop. My pc wouldnt boot. I discovered that by pushing the Ninja down a little bit (not towards the CPU but down towards the floor) I could get it to boot again. I had to put a small object between the top of the Ninja and the case's frame in order to boot all the time. After a while it stopped working all together. I tried everything possible from new memory to different PS and nothing. I RMAed it to DFI and got it back yesterday. Tried it at stock and all was good. Tried a small OC at 250FSB and fine but then at about 20 to 30 mins my pc froze. I tried booting up and the damn long beep loop showed up again!!! I assume that there is some weak component in my dfi that wont take the Overclock and is killing the mobo eveytime I OC. Then again, I didnt try stock speed to long either.
Right now I decided to try pushin down on the Ninja again and it worked! I am really confused on whats going on here. According to most people the long beep is memory related so why does pushing down on the Ninja helps?
Pleas help
PS I am well experienced on computers and OCing but this has me totally confused.
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
shaolin95 is offline   Reply With Quote
Old 02-15-2006, 12:07 PM   #2
D_o_S
D_o_S's Avatar
Originally Posted by shaolin95
Hi!
Pleas help
Perhaps your CPU is not seated properly? Or the socket is being ripped out of the mobo under the weight of the Ninja?
__________________
"Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
D_o_S is offline   Reply With Quote
Old 02-15-2006, 12:44 PM   #3
shaolin95
shaolin95's Avatar
I thought the same but that will mean that placing my PC horizontally will prevent that problem but it wont. And on top of that, it will make more sense if I have to push up on the ninja not down.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Old 02-15-2006, 12:50 PM   #4
EnJoY
XIP
EnJoY's Avatar
Send a message via ICQ to EnJoY Send a message via AIM to EnJoY Send a message via MSN to EnJoY Send a message via Skype™ to EnJoY
Did you take off the ninja an examine things closely?
EnJoY is offline   Reply With Quote
Old 02-15-2006, 01:21 PM   #5
shaolin95
shaolin95's Avatar
Yeah like 20 times already.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
