Originally Posted by gomeler
How efficient are compressors on their powerdraw versus output? My compressor is rated at 7.3 amps @ 115 volts = 839.5 watts. There is no way this is a 1hp+ compressor (746 W per HP) What is the efficiency rating on a compressor? ~60%?
One other question, is it possible to have too large of a condenser? I'm tearing into a dehumidifier and I'd just like to use the entire condenser/evaporator unit that came in it, 4 rows deep by 14 rows high. Trying to avoid making mistakes on this build, any help is appreciated.
7.3amps would be in the area of a 1/2hp to 3/4hp. Look up the specs on it ,it might tell you all you need to know.And yes too large of a condensor can hurt ur system (you may not get a continues stream of liquid at the outlet.)
__________________
My Rig:
Q6600 2.4Ghz@2.9Ghz Custom Liquid Cooling
ATI X1950XTX 512mb DDR4
MSI 975X Platinum PowerUp Edition
2gb Kingston Hyper-X DDR2 667
Sound Blaster Audigy2
2 IDE HDD, 2 SATA HDD
LG DL16XDVD Writer,52X CDROM
OCZ 520Watt PSU 33Amp +12v
Thermaltake Xaser III case
Logitech Z560 4.1 400watt Surround Sound
3Dmark03-21112
3Dmark05-12154
3Dmark06-8054
