XtremeSystems Forums
Reply
Old 02-05-2006, 02:47 AM   #1
JoeBar
Xtreme Mentor
JoeBar's Avatar
Quick question.
I'm going to be watercooled tonight and have an installation question.
I have a 120mm radiator. I'm going to install it on the back 120mm fan. Is it better to install it inside the case with the fan mounted on it or outside the case with the rear fan inside?
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
JoeBar is offline   Reply With Quote
Old 02-05-2006, 03:01 AM   #2
MaxxxRacer
Xtreme X.I.P.
MaxxxRacer's Avatar
Send a message via AIM to MaxxxRacer Send a message via MSN to MaxxxRacer
Depending on the rad it could be better to have air suckign through it or being pused through.
If you let me know the model number I will tell u which would be best.
other than the aformentioned item, just set it up whatever way is easiest for you.
MaxxxRacer is offline   Reply With Quote
Old 02-05-2006, 03:39 AM   #3
JoeBar
Xtreme Mentor
JoeBar's Avatar
Thanks for the answer.
I have Tt's BigWater SE.
This is my first w/c setup and i've decided to go mainstream.
__________________
Watercooling setup:
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
