XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 01-22-2006, 10:11 AM   #1
One_Hertz
One_Hertz's Avatar
Send a message via MSN to One_Hertz
sli 7800gtx 256... what cooling?
Hey guys I've been out of the air cooling news for a long long time since I got watercooling but now I am changing to phase change on cpu and air for gpus... Just wondering if the arctic silencer is still the best option for sli?
One_Hertz is online now   Reply With Quote
Old 01-23-2006, 09:26 PM   #2
Nanometer
Xtreme Mentor
Nanometer's Avatar
Send a message via AIM to Nanometer
Get the Zalmans if you have good case flow. Or go for a silencer with a vantec tornado mounted.
Why don't you wanna stick with water on your GPUs? Maybe even go tec on the GPUs?
__________________
PC Lab Qmicra V2 Case SFF
i7 950 4.4GHz 200 x 22 1.35 volts | Cooled by Swiftech GTZ - CPX-Pro - MCR320+MCR220 | Completely Silent loads at 66c
GTX 260 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II | Xigmatek Northbridge cooler mounted to the stock system.
OCZ Vertex RAID-0(60Gig x 2) | WD 1000Gig Storage
Enermax Liberty 620| With a low speed yate, the stock ball bearing fan crapped out after 1 year of service.
Nanometer is offline   Reply With Quote
Old 01-23-2006, 09:37 PM   #3
Coroner Kyle
Coroner Kyle's Avatar
I'm running Silencers on my GT's in SLi, but I've been considering water if I can find the space in my case, but I will have to look into tec.
Coroner Kyle is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
