XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware
Reply
Old 01-20-2006, 04:04 PM   #1
One_Hertz
One_Hertz's Avatar
Send a message via MSN to One_Hertz
Going sli... a few questions
First of all I'll start with my system specs:
amd 3800+ X2 2.6 (288*9)
Corsair xms 2gb 288mhz 3-4-3-6@2.75volts
XFX 7800gtx (490/1300 one)
DFI NF4 Ultra-D
PC Power and Cooling 510watt Deluxe
two 74gig raptors in raid0
X-FI xtreme music sound card
Alright I am doing a major upgrade (stupid 3d06...lol). I want to buy a second gtx identical to the one I have, and I am also buying phase change cooling to put my cpu at like 3ghz . The biggest thing I am wondering is whether I'll need a new motherboard or not? Dfi says that my mobo doesnt support sli but I think I saw that sli can be easily enabled on the ultra'ds and runs perfectly fine. The second thing I wanna know is if my psu can ahndle another gtx added to this system... The nvidia website says 30amps on the 12v rail for sli gtx and I have 34amps, so i should be ok? Not planning to oc the vcards for 24/7 use... My psu is also supposedly sli certified... Overall, does anyone see any problems with me buying another gtx and switching cooling to chilly1 phase?
One_Hertz is offline   Reply With Quote
Old 01-20-2006, 04:08 PM   #2
One_Hertz
One_Hertz's Avatar
http://www.ocforums.com/showthread.php?t=386010
Is this guide correct? Where can I get those "bridges" they talk about in the guide? Can I just solder the two things circled in black?
Old 01-20-2006, 04:32 PM   #3
cx323
that guide is right. you can solder the one's in the black circle to get sli. just so you know some of them have paste over the contacts, but if you scrape it off you'll be fine.
cx323 is offline   Reply With Quote
Old 01-20-2006, 07:41 PM   #4
One_Hertz
One_Hertz's Avatar
any more inputs? on psu mostly....
Old 01-21-2006, 09:10 AM   #5
One_Hertz
One_Hertz's Avatar
bump
Old 01-21-2006, 09:13 AM   #6
nn_step
YouTube Addict
nn_step's Avatar
If it is SLi certified it will work just fine unless you wanna upgrade it too..
Get PCP&C if you can
__________________
Impossible is not a fact; it is an opinion. Impossible is not a declaration; it is a dare.
It's hardware that makes a machine fast. It's software that makes a fast machine slow.
Fast computers breed slow, lazy programmers
Algorithms + Data Structures = Programs
And all of that source is portable, except for this tiny kernel that you can (provably: I did it) re-write totally from scratch in less than a year without having /any/ prior knowledge.
-Linus Torvalds
http://www.youtube.com/watch?v=ANtpsunRYIs
http://www.youtube.com/view_play_lis...23537556D7AADB
http://www.youtube.com/watch?v=QTcFLp1uVZ4
Science is simply common sense at its best that is, rigidly accurate in observation, and merciless to fallacy in logic.
http://pix.motivatedphotos.com/2009/...raindamage.jpg
nn_step is offline   Reply With Quote
Old 01-21-2006, 12:22 PM   #7
Dj_iNSULIN
Dj_iNSULIN's Avatar
just try it. if your system gets unstable, it may not provide enough power.
I don't know how much your PSU gives at +12V, but my system (x2 4400+, 2 6800GT's and A LOT of stuff) doesn't get enough power with 36A
Dj_iNSULIN is offline   Reply With Quote
Old 01-21-2006, 12:23 PM   #8
p00 p0wer
p00 p0wer's Avatar
your dfi-sli d might support sli. If it was one of the first board manufactured it can be modified to sli. i believe i read elsewhere that dfi had taken steps so you could no longer modify the board.
__________________
AMD 64 3700+ @ 280x10=2.8Ghz @1.525v DFI SLI-DR
1 GB G-Skill LA @ 2.5-4-4-8 3@ 2.8v
ATI x1800XT PE (owning 7800gt's SLIed)
Moded G5 case
p00 p0wer is offline   Reply With Quote
Old 01-21-2006, 01:32 PM   #9
One_Hertz
One_Hertz's Avatar
uh-oh I dont wanna buy all thios stuff and then realize that my mobo doesnt support it. Anyway I can tell without actually attempting the mod? I can't try to do it cause all my watercooling is rigged up now and it will take me like 12 hours to take it off and put it back. What kind of precautions are you talking about? If I try the mod and it can;t be modded can any permenant damage be done?
EDIT: read some stuff on that and didn't really find anything preventing the ultra to be enabled.... On the latest mobos however some epoxy is used to cover the resistorsthat need to be connected. the epoxy can be easily removed...
Old 01-21-2006, 06:43 PM   #10
p00 p0wer
p00 p0wer's Avatar
i thought they had taken other precautions but i might have been wrong. then again i never paid close attention to it becasue i own a sli-dr.
__________________
Moded G5 case
Old 01-21-2006, 11:44 PM   #11
pissboy
I was going to ask you if you had one, but I guess you dont. I'd check ebay, although it looks like there are only Asus ones for sale on there. The main difference is just the length. The other thing to keep in mind is on the DFI nf4 ultra board you'll be running one slot at x16 and the other at x2 if I remember that correctly.
pissboy is offline   Reply With Quote
Old 01-21-2006, 11:51 PM   #12
einCe
pepsi fiend
einCe's Avatar
Send a message via ICQ to einCe Send a message via MSN to einCe
theres not any apparent danger, just remove the northbrigde heatsink, ans solder, or pencil the two contacts together, takes 5 minutes
__________________
Lanparty Ultra-D DEAD|REVIVED
X2 3800+ LDBHE 0606 EPMW 2950 @ 1.55v DEAD|STILL DEAD
Powercolor X1900XT 725/873
dell 2005fpw 20.1''
Originally Posted by afireinside
"uh yeah is this DFI RMA dpt? yeah I was setting up your ultra-d motherboard last night and the pwm shot a flame at me... can you give me a new one?"
Originally Posted by Mr. Popo
if you wont eat all of your vegetables einCe will come and get you!
einCe is offline   Reply With Quote
Old 01-23-2006, 02:59 AM   #13
Daveb2012
Daveb2012's Avatar
Send a message via AIM to Daveb2012
i have same board it can easily be modded.
__________________
Current Setup:
-9850 GX2's in Quad SLI config
-Asus P5N32-SLI MB
-2x512mb of PC2-5300 DDR2
-Intel Celeron D OC'd to 3.2Ghz
-Windows Me with XP theme
-WD Caviar 20GB Hard Drive
-Zip drive
-Jazz drive
-3.5" floppy drive
-5.25" floppy drive
Daveb2012 is offline   Reply With Quote
Old 01-23-2006, 05:25 AM   #14
IYP
Send a message via AIM to IYP
dont the new drivers support brigeless SLI?
__________________
afireinside on AIM :: I just about got walked in on because my mom wanted to show me her website :|
IYP :: hahaha
afireinside :: friggin ruined my night
VOTE YES FOR A MOBILE PHONE SECTION HERE
Need a new screen? Go to THE LCD BUYERS GUIDE
IYP is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
