XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 01-12-2006, 09:13 PM   #1
shaolin95
shaolin95's Avatar
Badly need help removing mobo...1 screw wont come off no matter what!
Hi!
I need to RMA my mobo but there is 1 screw that wont come off no matter what. I tried moving back and forth and now I cant even make it turn. Do you think drilling it could work?
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
shaolin95 is offline   Reply With Quote
Old 01-12-2006, 09:25 PM   #2
BLHealthy4life
BLHealthy4life's Avatar
Drilling would work, however, very dangerous to do.
Use pliers to grab the screw and turn it. you just need to get some leverage on the screw to overpower its restraint.
good luck.
BLHealthy4life is offline   Reply With Quote
Old 01-12-2006, 10:08 PM   #3
illmatik
I just had a similar problem w/ a mobo standoff (the tapered coolermaster ones) that worked its way into the corner hole of the and just would not budge, nor could i get underneath to try to make it move w/ a small flat wrench. If you have a little bit of give between the top screw and the mobo and also have access to where the standoff is screwed in you could use a drill to help loosen the standoff. From behind the mobo tray drilled a very small hole in the standoff screw so that I could get a good grab in it with a precision screwdriver. I gently tapped a flat head precision screwdriver in the standoff and then slowly loosened the standoff to get it out of the mobo tray. Once I got the whole board out I used a pair of robogrip pliers to separate the offensive screw and mobo standoff. I couldnt get a good grab of the screw w/o risking a slip that would scratch the pcb so the other method worked out safer for me.
illmatik is offline   Reply With Quote
Old 01-13-2006, 10:50 AM   #4
shaolin95
shaolin95's Avatar
Gonna check which option works...wish me luck.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
