01-07-2006, 10:18 AM
#1
Xtreme Old School Moderator
SCYTHE NINJA SCNJ-1000 - A really impressive cooler
I tried a Ninja and I must say I'm really impressed with the cooler performance
Assembled with 1 SILENX iXtrema PRO SERIES 120MM (42CFM / 11 dbs ) really silent.
The cooler mounting its quite easy.
The cooler is really HUGE, almost do not pass on the Lian Li on mouting the motherboard tray
Here is a photo:
LianLi box with SEASONIC S12-600 600W SLI SUPERSILENT - Absolut Silence
Here is a result with 1 FX-57
Idle 33º - running superpi a 3160, never passed 42ºC - amazing ..at this speed / voltage the cooper Zalman 7000 goes higher than 50º :
With the Ninja 3220Mhz benchable (3Dmark and superpi) in the FX-57 is possible, I never saw this with other air coolers I tried ..
And this without any noise - a lapot make more noise noise than this - It's the ideal cooler for 24/7 use
I strongly recomend this cooler
01-07-2006, 11:03 AM
#2
Glad to see you liked the Ninja. Its an superb cooler and my favorite but here BT is the fan favorite. Still, the flexibility of the ninja is second to none. I got my fan blowing up and it keeps the pwmic and chipset really cold and since hot air goes up anyway, the two fans on my case's top get rid of hot air faster this way.
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
01-07-2006, 02:05 PM
#4
130 mm fans? maybe you can fit even 140 mm?
I looked around and I opted for the Ninja so I am eagerly listening to everyone that praises it lol. I just couldn´t see how the BT would serve me any better...
Have heard you can not use those wider fans on it. Has a YS Tech mega CFM fan which I have planned to tune down with a fan controller so I could get the perfect mix. But from pictures of the Stacker I think it would do the job perfectly as the exhaust fan helping suck air through it. Guess it´s to wide to use on the 4-3 modules? And then run the Tri cool on the Ninja instead if it doesn´t fit. Or I could direct it upwards to the 80 mm blow hole but that doesn´t seem as optimal but what do I know  .
I am getting the cross flow fan as well so not to worried about my chipset and ram temps
As for the Sonic Tower it´s taller but it does get beaten consistantly all the time by the ninja. And I have seen really worrying pictures on what pressure it puts on the mainboard. Seems like you need to support it by some wires or you risk it cracking the mainboard and CPU.
__________________
Coolermaster Stacker
Silverstone 850 zeus
Core 2 duo E6600
Asus Commando
2x1 gb team xtreme
Leadtek 8800 GTX
X-Fi ELITE PRO
2X WD Raptors
2x WD 500 KS
Laing DDC 2 pump with petra tech top
12 mm tubing
Apogee and MCW60
Microres reservoir
MCR330 triple rad and radbox.
01-07-2006, 03:07 PM
#5
nice cooler .. got it here 6months ago ... tried to mount on an winni without IHS .. no winni is dead
__________________
AMD 3700+ KAB3E 0546 GPMW @ 300*10 | DFI nF4 Ultra-D | 2x512 TwinMOS Speed Premium 400 - UTT|MSI 7800GT @ 515/1200| Antec Phantom 350 | Alphacool NexXxos XP | Mora 2 | Innovatek HPPS
01-07-2006, 04:09 PM
#6
Finally, I found the cooler, and psu I need to make my system quiet. Nice setup you got.
01-07-2006, 04:26 PM
#7
Yeah, same cooler i had on mind. Seems impressive so far. Nice competitive performance, price, quiet and not as heavy as some others.
I read somewhere about a new planned Scythe Ninja, made all of copper.  Who knows...
01-07-2006, 07:12 PM
#8
Here is a simple mod to fit bigger fans to the Ninja:
Regards
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
01-07-2006, 08:38 PM
#9
I'm sure it will lower temps (even if by just a couple of degrees) but, I think one of the best parts about the Ninja is that it is relatively light (665g) compared to other high performance coolers (TTBT @ 813g and XP-90C @ 690g).
I think a part copper, part aluminum HS is the best combination. Take the Cooler Master Hyper 6 for example, first gen. was all copper, but that was phased out in exchange for design much like the current Ninja.
__________________
AMD Athlon 64 X2 3600+ @ 3.0GHz||Biostar TF560 A2+||4x1GB Team Xtreem D9s||Visiontek HD3870||WD 250GB||Seasonic SS-600HT
AMD Athlon 64 X2 3800+ @ 2.6GHz||DFI NF4 Ultra-D||OCZ VX 4000 2-2-2-5||ATI X1900XT||Seagate 320GB||Seasonic S12 600
01-09-2006, 10:05 AM
#10
Yes looks like Scythe was really clever. Look at the Sonic tower and how much pressure it puts on the PCB. You need to support it by wires really since it has so much weight at the top.
So I guess using aluminium was kind of a necessity with such a high rise cooler...
But now how does this work with X2:s with removed IHS? Do you need to mod the clamping to fit well or anything? Is there a big risk it will crush the core?
__________________
Core 2 duo E6600
Asus Commando
2x1 gb team xtreme
Leadtek 8800 GTX
X-Fi ELITE PRO
2X WD Raptors
2x WD 500 KS
12 mm tubing
Apogee and MCW60
Microres reservoir
01-09-2006, 12:51 PM
#11
Regards
Do you really need such a big fan ?
What where the gains in temperature ? 2º C ?
01-09-2006, 01:32 PM
#12
I've choosen the Zalman 9500, seems like i decided wrong
greetz
__________________
AMD X2 3800+ 0601 TPMW | DFI Lanparty UT nF4 SLI-DR Expert |
Point of View 7800GT | 2x1GB G.Skill HZ | Tagen TG480W-U01 |
Seagate 120GB | Aerocool T3 *25cm Fan* | Sennheiser PC160 |
01-09-2006, 03:33 PM
#13
2º C  I really wish you are just kidding..... that is a delta 152cfm not a silent 30cfm fan...do the math, it may not help with other coolers but the ninja is another thing, also there is something called air flow...in other words, get real. Still, I know you werent really interested in an answer were you?
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
01-09-2006, 05:13 PM
#14
that's a great semi passive heatsink , nice temps
__________________
E8200
EP45-UD3R
2*2Go OCZ reaper 8500
BFG 8800GTS 640M
01-12-2006, 08:19 AM
#15
Can you use the Ninja with a Opteron without IHS without mods?
__________________
Core 2 duo E6600
Asus Commando
2x1 gb team xtreme
Leadtek 8800 GTX
X-Fi ELITE PRO
2X WD Raptors
2x WD 500 KS
12 mm tubing
Apogee and MCW60
Microres reservoir
01-12-2006, 08:29 AM
#16
I installed a Ninja on Tuesday night. I got a 2c drop in temps from an XP-90 with a Delta 3-blade. While 2c doesn't sound like much the difference in the noise level because of replaceinf the Delta, 2 Antec 120's, and an Evercool 120, with 4 Yate-Loons was astonishing. You can barely hear the fans. I can now hear the stcok hs/f unit on a PIII-800 running in my file server sitting beside my desk and not the main system which used to sound like a small hovercraft with the fans all on high. It is the best air cooler I have ever tried.
oqvist I know I would not want to try mounting the Ninja on a naked chip. It took a lot of force to hook the clips. The hs is akward to hold while hooking the first two.
01-12-2006, 05:53 PM
#17
2C sounds like a way too small improvement from the XP90. I will think you need better air flow managament or perhaps the Artic silver needs to "cure". I would expect a 5C at least.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
01-12-2006, 06:08 PM
#18
Xtreme Mentor
I also have the ninja. It is very nice indeed.
__________________
Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
—Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
01-12-2006, 06:57 PM
#19
You missed my point. 2c improvement while making the system almost silent is a big improvement. I did change something in the airflow that maybe did work against me but I don't think so. I had 4 fans with the XP-90, the 92 Delta, an Antec 120 in the front and also one in the back blowing in, plus an Evercool in the top blowing out. All 4 or those fans will move a bunch of air but they do it loudly, especially the Antec's. When I installed the Ninja, I switched to 4 Yate-Loon 120's. One in front blowing in, one on top blowing out. The other two are set up to blow through the Ninja into the back case fan which now blows out. This box sits inside of a compartment in an oak rolltop and it can get very hot inside that compartment. That is why I decided to set the back fan to blow out, why bring in warm air, much warmer than room ambient. While cpu temps only went down 2c, case temps have dropped 8c - 9c. And remember a Delta equiped XP-90 is not a bottom feeder (or stock) cooler. And yes, I would imagine another 1c -2c drop once the AS5 settles in, as it usually does.
Bottom line, for me, is this. I have achieved an improvement in cooling while at the same time making the system almost totally silent. I don't even have to hear a chipset fan as I run an A8n-SLI Premium, which has a heatpipe fanless chipset cooler. At the same time I have vastly improved case cooling which I needed for my migration to an SLI setup. 2 gpu's will need all the cool they can get. If I never see another 1c improvement, I am still satisfied.
01-14-2006, 06:02 AM
#20
And ? what where the gains ?
01-14-2006, 11:12 AM
#21
I've used the ninja and the tt bt.... better results with the tt bt
__________________
01-14-2006, 06:48 PM
#22
that looks like a excellent cooler.
I'm looking to replace my xp-120 as i'm seriosuly not impressed with the temps
__________________
01-14-2006, 09:29 PM
#23
I was in the same position as you. My SI-120 wasn't anything better than my XP-90, so I bought the Ninja. Hoping for lower load temps
__________________
01-24-2006, 09:32 PM
#24
FYI - Ripped from Ben's:
CensusPC.com has the Ninja Heatpipe CPU Cooler for Socket (478/ 775/ 754/ 939/ 940) for $38 - $5 code CPSS762 [Exp 1/31] + $6 shipping = $39 shipped.
Link-a-dink-a-doo.
__________________
Bench rig now in constant change, with scraps thrown to my game rig. 2x8800GTX + e8400 = 29K 3DMark05
01-30-2006, 11:11 AM
#25
can i have an opinion on this configuration i'm planning for my system
Front intake and Rear exhaust 120mm Yate Loon fans
Ninja mounted to the x2-3800 (non-OCed system)
Coolermaster 120mm fan attached to the right of the hs (looking from the top) in a push fashion
does this sound (no pun intended) ok from a noise/cooling perspective?
3 questions:
-Will i have enough clearance to mount the 120mm fan to the ninja overtop ocz platinum memory?
-It looks as though the HS snaps into the supplied retention bracket. is it difficult to remove afterwards?
-AS5 or AS ceramique?
thank you for helping this newbie
__________________
Intel BX2, Q6600, 2x2GB Mushkin EM2, XFX 8800 GTS 512mb, S12-600W, Auzentech Prelude, Silverstone TJ09, Thermaltake Ultra 120 Extreme
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
