XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 12-15-2005, 08:49 PM   #1
nhenhophach
Xtreme Cruncher
nhenhophach's Avatar
Send a message via MSN to nhenhophach Send a message via Yahoo to nhenhophach Send a message via Skype™ to nhenhophach
Can repair CT-479??
My friend plug a Celeron-M 3(1.2, 256k) in my CT. Then never boot. It mean CT die??. And can repair it??. Thanks everybody.
__________________
Are you overclocker? Your PC fast? Join WCG to help community
Big thank to: heater918, DDT, Movieman, Mad mikee
Special thank to Centon
nhenhophach is offline   Reply With Quote
Old 12-16-2005, 12:56 AM   #2
cirthix
The un-extreme XIP
cirthix's Avatar
Send a message via AIM to cirthix
are you sure that the bios you are using supports the ct479? thats usually the problem. have you tightened the screw to secure the cpu and is the power plugged into the adapter?
__________________
Q6600@3.6ghz 1.45V ----- 8gb ocz ddr2-1000
XFX 5850@900/1200 1.15V
1TB hitachi+2x30gb OCZ Vertex v1.41 raid 0
520HX corsair power supply ----- half-size shuttle!!
30" 3007wfp-hc 2560*1600 lcd
unicomp clicky keyboard+logitech trackball
cirthix is online now   Reply With Quote
Old 12-16-2005, 01:24 AM   #3
nhenhophach
Xtreme Cruncher
I am sure!. I use it with P4p800-SE. Before I run with Pen-M 730 .
__________________
Old 12-16-2005, 02:34 AM   #4
sky
sky's Avatar
Send a message via ICQ to sky Send a message via AIM to sky Send a message via MSN to sky
i have a cm320 that also wont boot with any board i have had. either its dead
or the bios' just dont support that chip... tried it on a aopen i855gmem lfs and
my p4p800se that i've been using with a 760 for the last hm 6 months
__________________
sky / s!p - we are oldskool, dammit.
sky is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
