XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 12-14-2005, 09:18 PM   #1
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
New Project
So after my first build, I've decided to correct my mistakes and try something new. I'm going to try to fit a single stage r290 1hp DD cooler into a SFF case. Has anyone done this before? Really want to make a nice clean package. On another note, anyone know of a better website to order flexible SS than BES out of the UK? I know a few members have websites that sell stuff, but I checked before and the prices were a bit steep. Have about 2 weeks to get this thing working, and trying to avoid using a solid copper line =)
Cliffnotes
Using SFF case to make a DD system
Need SS lines
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 12-14-2005, 09:53 PM   #2
MeltedDuron
Dothan FTW!
MeltedDuron's Avatar
Send a message via AIM to MeltedDuron Send a message via MSN to MeltedDuron Send a message via Yahoo to MeltedDuron
1hp? !!!
__________________
.:Melted's Hardware:.
.:My Workstation::Sorta Done:.
.:Intel E4300@3ghz(375*8):2gb G.Skill HZ 6400@500mhz:Sapphire X1950pro:Gigabyte GA-G33M-DS2R:550w FSP Blue Storm:80gb and 160gb WD SATA2:Cheap MATX Case:.
.:Panasonic Toughbook CF-T2:.
.:Pentium M 753 (900mhz ULV):256MB:40GB:12.1" Touchscreen:. .:Not too shabby for a 2.4lbs of pwn:.
I've been using Intel ever since AMD put an end to my socket A fun. I was almost going to go back when I saw the cheap AM2 chips, but they suck Viva La Chipzilla!
MeltedDuron is offline   Reply With Quote
Old 12-14-2005, 09:59 PM   #3
gclg2000
gclg2000's Avatar
Send a message via AIM to gclg2000
you do realize how big a 1 HP compressor is...
__________________
I like building Vapor phase coolers......
......to cool mynipples!!
Heat is "gclg2000"
95-0-0
-100C Cascade Club
gclg2000 is offline   Reply With Quote
Old 12-14-2005, 10:00 PM   #4
dave_graham
dave_graham's Avatar
Send a message via MSN to dave_graham
wow...sounds like an interesting project...SFF-wise, i'm a bit intrigued as to how you're going to fit it in there.
dave
__________________
Heat: 50 - 0 - 0 under "Argus333"
dave_graham is offline   Reply With Quote
Old 12-14-2005, 10:08 PM   #5
wdrzal
I am Xtreme
wdrzal's Avatar
what about all the heat the compressor gives off??????
wdrzal is offline   Reply With Quote
Old 12-14-2005, 11:17 PM   #6
[XC] gomeler
lol woops, it isn't a 1hp compressor, i misread the label =) its a little LG compressor, I believe it spent a few years inside a mini fridge, about 1/3 hp. with my limited knowledge of compressors, I'm not too worried about heat production, there should be enough condenser to keep the gas chill and permit some cooling liquid to return to the compressor, the load will be an overclocked XP 2400+ T-bred. Anyone have ideas for flexline? don't really want to have to order from across the pond.
__________________
Old 12-14-2005, 11:21 PM   #7
gclg2000
gclg2000's Avatar
no offense, but try again....he's not talking about that...
__________________
Heat is "gclg2000"
95-0-0
-100C Cascade Club
Old 12-14-2005, 11:42 PM   #8
[XC] gomeler
are you talking about the compressor itself, being confined in such a small area, that perhaps temperatures would reach a point where it would fail? if so, can it be worse than where it was living before? refridgerator's don't exactly have prime airflow.
__________________
Old 12-15-2005, 03:11 AM   #9
Gray Mole
Gray Mole's Avatar
I've thought about using the SFF and micro cases for the phase change case, and it seems like a good idea. As long as you didn't want to put the pc in there, just the phase kit like a prommie then it would work fine, and leave room for a larger compressor if needed. 120mm fan in and out would be enough for compressor cooling, and with R290 you're not getting high discharge temps anyways.
The flexlines from BES work ok, but 600mm is the longeest they sell, and you have to put adapters onto the ends.
FlexiJ sells custom lengths in you call them, and I've heard the prices are reasonable, but call 'em and they'll quote you.
Gray
__________________
Nearly back from the dead.
Gray Mole is offline   Reply With Quote
Old 12-15-2005, 09:59 AM   #10
[XC] gomeler
Can you link FlexiJ's website or phone number? Google just pulled up a bunch of random garbage about webcams and salt and pepper shakers. For the BES lines, 2 feet did seem a bit short, but I plan on having the SFF sit right on top or beside the case. Thanks for the help.
__________________
Old 12-15-2005, 10:58 AM   #11
Gray Mole
Gray Mole's Avatar
http://www.flexej.co.uk/content/P12.htm
I've heard they're not too bad, and do custom sizes and all that, but I've never dealt with 'em myself.
Gray
__________________
Old 12-15-2005, 07:25 PM   #12
[XC] gomeler
you know if they ship to the us? I'm based around the Atlanta area =)
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
