XtremeSystems Forums
Reply
Old 12-14-2005, 05:16 PM   #1
shaolin95
shaolin95's Avatar
Aquagate mini 120 beats Big Typhoon...is this for real?
I just read this review:
http://www.3dxtreme.net/index.php?id=cmaquagater1204
What do you think about this? If this review has any credibility I may be tempted to try this.
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
shaolin95 is offline   Reply With Quote
Old 12-14-2005, 05:19 PM   #2
n00b 0f l337
I am Xtreme
n00b 0f l337's Avatar
Send a message via MSN to n00b 0f l337
Probably not real.
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
n00b 0f l337 is offline   Reply With Quote
Old 12-14-2005, 06:02 PM   #3
shaolin95
shaolin95's Avatar
Too good to be true?
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Old 12-14-2005, 06:05 PM   #4
n00b 0f l337
I am Xtreme
Too crappy to be possible!
__________________
NoL: gom gom gom
Old 12-14-2005, 06:07 PM   #5
shaolin95
shaolin95's Avatar
Well, Maximum PC also rated it pretty good...if thats worth anything :-)
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Old 12-14-2005, 06:12 PM   #6
MadMikeSS
MadMikeSS's Avatar
Send a message via ICQ to MadMikeSS Send a message via AIM to MadMikeSS
Ask dnottis, he's the one using it and it's his review. He's getting better results with the Aquagate than he did with his Big Typhoon, and I'm confident he knows what he's doing.
__________________
~MadMikeSS~
Intel Q6600 G0 @ 3.2GHz 1.31v - AX MP-05 SP LE cooled
P5B Deluxe 1236 BIOS
HIS HD4850@750/1100 - AX MP-1 cooled
Mushkin 4GB(1GBx4) DDR2-800 5-4-4-15 1.9v
FSP 700W PSU
Lian-Li PC-V2000B
MadMikeSS is offline   Reply With Quote
Old 12-14-2005, 06:14 PM   #7
shaolin95
shaolin95's Avatar
I wonder why it is not more popular...perhaps a case of people passing judgment before trying it?
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Old 12-14-2005, 06:15 PM   #8
n00b 0f l337
I am Xtreme
Its hard to beleive. I've had kits like that. I'd take stock heatsink over them. I feal he may have done a good review. But what was he reading temperatures with?
__________________
NoL: gom gom gom
Old 12-14-2005, 06:20 PM   #9
shaolin95
shaolin95's Avatar
I dont see much logic on this statement honestly. Is like people dismissing Big Typhoon cause it was made by thermal take.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Old 12-14-2005, 06:23 PM   #10
n00b 0f l337
I am Xtreme
No no, Ive had a lot of those kits or had friends that bought them against advice. I know someone with that exact kit. His presscot is constantly overheating while gaming.
__________________
NoL: gom gom gom
Old 12-14-2005, 07:43 PM   #11
Bloody_Sorcerer
beefin' it up!
Bloody_Sorcerer's Avatar
Send a message via AIM to Bloody_Sorcerer Send a message via MSN to Bloody_Sorcerer
my friend has a thermaltake bigwater... he has to underclock his 3500 (iirc) to remain stable in a fairly cool room. utterly pathetic.
__________________
HD 5850 inc!
Bloody_Sorcerer is offline   Reply With Quote
Old 12-14-2005, 08:02 PM   #12
dnottis
Xtreme Mentor
dnottis's Avatar
Im using the same exact OS install and MBM5 install, same as I used for all the air coolers - the only thing that changed was the CPU coolers. Did it beat the Big Typhoon? Yes. Fair and square.
However I am using a reverse ATX case which I feel is really optimal for the Aquagate system. Allowing me to mount the unit at the front of the case and pull cool air into the case and exhaust with another 120mm fan out the back. (check the pics in the review) Other reviews with the Aquagate in a standard ATX will not get cool air blowing in, it would be blowing air from within the case through the Aquagate and out the back of the case.
This is why I think my results were so much better - and yes all of this was explained in the review.
I'm trying to get Thermaltake to send the Silent Water over... more l/h (72 vs 45) and top mounted tubes...
Maximum PC had great results with the Aquagate and one of the companies (Falcon maybe) are shipping it with an overclocked FX57. The R120 is not as good as a real water cooling system, but it has proven to be better than the best air. And as far as running a 150 CFM fan, no thanks I need quiet. I replaced the stock fan with a Thermaltake adjustable fan after the review and it's running nice and quiet now.
Dean
__________________
Q9550 @ 4.105 Ghz
Gigabyte P45 UD3P F9
G.Skill PC2-8800 DDR2-1100 8GB Memory
1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, D-Tek FuZion pro mounted, FuZion GFX 2
Cooler Master UCP 1100 Watt PSU
MSI HD5870 1Ghz (1.16v), 1300Mhz
Lian Li PC V-2000
Acer X222Wbd 22" LCD
3 x WD 640GB WD6400AAKS HD
Pic of my watercooled rig
dnottis is offline   Reply With Quote
Old 12-14-2005, 08:14 PM   #13
sin0822
how long you let it go, i find htat these little systems overload after a couple hours of full load.
__________________
Originally Posted by masterofpuppets
I got out a knife and scraped SMD chips off of my P4C800-E cos it wouldn't overclock as far as I want.
sin0822 is offline   Reply With Quote
Old 12-14-2005, 08:18 PM   #14
dnottis
Xtreme Mentor
dnottis's Avatar
Prime long hours.
Here was at 10 hours - load was 39 deg c. 2900 1.50v
2920 1.55v load 41 deg c.
__________________
Q9550 @ 4.105 Ghz
Lian Li PC V-2000
Old 12-14-2005, 08:18 PM   #15
dnottis
Xtreme Mentor
dnottis's Avatar
I think that should prove that long hours of load dont overcome it.
Also, with the Big Typhoon I needed 1.52v for 2900 and 1.55v for 2920, load temps were 45 and 48 respectively.
__________________
Q9550 @ 4.105 Ghz
Lian Li PC V-2000
Old 12-14-2005, 08:22 PM   #16
dnottis
Xtreme Mentor
dnottis's Avatar
Exactly - Thermaltake nailed a grand slam with the Big Typhoon - definitely the BEST air cooler!
__________________
Q9550 @ 4.105 Ghz
Lian Li PC V-2000
Old 12-14-2005, 08:23 PM   #17
sin0822
thats wierd becaue after 30 mins of full load at 180 watts i had overpowereed the R80 which is the 80mm verison of the same cooler to 56c and above 180 watts for over 30 mins would manke the system unstable.
__________________
Old 12-14-2005, 08:34 PM   #18
dnottis
Xtreme Mentor
dnottis's Avatar
I doubt an AMD64 Opteron would put out 180 watts though. Had we used an Intel Press-HOT CPU Im sure the results would be different.
__________________
Q9550 @ 4.105 Ghz
Lian Li PC V-2000
Old 12-14-2005, 08:38 PM   #19
sin0822
yeah probably, never the less good findings.
__________________
Old 10-23-2006, 12:50 PM   #20
rfhop22
I know this is an old thread but I just wanted to post my experience with the mini R120.
First off I picked it up for $50 at newegg. Put it on my new C2 e6600 / P5W DH. I place the Rad in front of cas with the fan pulling air thru it. Now I was concerned in the beggining about my temps in load. Idle would very from 24c-28c and load would go up to 60c with 2 instances of prime. Thought maybe my Wb wasn't makin good contact but the rad was warm.. well hot actually so it was doin the job. I wanted to try something before I re-installed the WB.
I put another 120mm fan in front of my rad to push air with a ghetto shroud made out of cardboard and 100 mile-n-hour tape. Push/Pull method worked wonders with this R mini.
My idle hovers 21c-22c and load with 2 instances of prime running for over 12 hours gets 38c.
My current OC for my e6600 is @ 3.2 Ghz 1:1 ratio 1600fsb. So far Im happy with it.
I only bought it cause it was cheap and newegg didnt have the Apex Ultra in stock at the time of purchase and I was just goin to fool around with it.
I have to say that with the added fan I get excellent results compared to just the 1 fan.
rfhop22 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
