XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware > Video Cards
Old 12-14-2005, 04:34 PM   #1
Arkangyl
Arkangyl's Avatar
Best ATI X1800 Brand?
Just wondering, are there any differences in OC ability between the brands? Sapphire and HIS seem the most popular but I don't know if that means much, it would appear all the X1800s, XLs in specific are made by either ATI or Sapphire.
Also, newegg has the Connect3D XL for about 30 less than the Sapphire or ATI model, does it not OC as well or is it just an underprice?
thanks
__________________
CPU:: i5 750
GPU:: GTX260-216
MB:: EVGA p55 SLI
RAM:: 4gb DDR3-1600
AUDIO:: Xonar Essence STX
Arkangyl is offline
Old 12-15-2005, 06:54 AM   #2
FireDragon
FireDragon's Avatar
Send a message via AIM to FireDragon
connect 3d suck stay away from it....
Dragon
__________________
http://smbach.com/mad.gif
Opty 175 Rig
Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
AM3 Rig
Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
DFI NF4 BIOS Guide
FireDragon is offline
Old 12-15-2005, 01:51 PM   #3
Arkangyl
Arkangyl's Avatar
thanks, the next price step up from there has Sapphire and they seem rather popular so if I go that route, Sapphire it is
__________________
CPU:: i5 750
GPU:: GTX260-216
MB:: EVGA p55 SLI
RAM:: 4gb DDR3-1600
Arkangyl is offline
Old 12-15-2005, 02:50 PM   #4
dvothecc
I'm happy with my Saphire X1800XT Overclocks well but im on water.
__________________
A64 3700+ (SD) Swiftech WC setup
DFI LanParty NF4 Ultra-D
2x 512M OCZ EL Platinum Limited Edition
Saphire X1800 XT
OCZ 520W PowerStream PSU
Silverstone TJ06
dvothecc is offline
Old 12-15-2005, 02:51 PM   #5
kiwi
Xtreme
kiwi's Avatar
Send a message via MSN to kiwi Send a message via Skype™ to kiwi
I would prefer BBA, Sapphire, Asus
__________________
kiwi is offline
Old 12-21-2005, 01:04 PM   #6
Sume4
Sume4's Avatar
Send a message via MSN to Sume4
With out of the box cooler -> Asus EAX1800XT TOP
__________________
Intell Core 2 Duo E6850 3,9ghz with water
DFi P35 Blood-Iron
G.skill 2x2Gb PK 5-5-5-12 1088mhz 2.2v
Sapphire Radeon HD2900Pro 1024mb GDDR4
Lian Li PC-V2000A
BENQ FP937s+ 19" TFT
Logitech UltraX USB keyboard
Logitech G5 Laser mouse
Sume4 is offline
Old 12-21-2005, 01:27 PM   #7
Hicks
3dMark Isn't Everything
Hicks's Avatar
Dragon
Erm why. All the cards are the same, apart from a sticker. Just get the cheapest.
__________________
Kentsfield Q6600@ 3100Mhz
Asus P5B-E Plus
2GB GSkill DDRII PC6400GBHZ
Albatron Geforce 8800GTX
Silverstone Temjin TJ-09
Thermalright Ultra 120
Corsair 620W HX
74GB Raptor/ X-Fi Platinum
19" CRT NEC 930 SB
Windows XP Pro SP2
Hicks is offline
Old 12-21-2005, 01:48 PM   #8
rick_fx
rick_fx's Avatar
True, and you won't necessarily get a better OC because you pay more for a certain brand name.
__________________
Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
*** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
rick_fx is offline
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
