12-08-2005, 12:42 AM
#1
Does this Microcool Chipsink Cooling kit really help stability or is there something
better?
Hi!
I wanted to know if its recommended to use this kit:
Microcool
If its recommended then I will need some help figuring out where to use the sinks on my DFI NF3.
Regards
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
12-08-2005, 12:47 AM
#2
XS Local
http://www.svc.com/sac-p01.html
These will do about the same, and cost alot cheaper.
just make sure you have good air flow through your case and you'll be fine.
__________________
Opteron 175 Dual Core CCBWE 0544XPMW @2.3ghz 1.41v
DFI SLI-DR Expert 11-25 Bios
G-Skill 1gb GH UTT @210 2-2-2-5
BFG 7800GT OC 485/1170 NV 5rev3
74gb Raptor 300gb Maxtor 500gb Hitachi
OCZ 520w SLI 3.46v 5.16v 12.64v
Thermaltake CL-P0114 Big Typhoon
3dmark01 3dmark05
Heatware
12-08-2005, 12:56 AM
#3
Great find! Do you think they actually do something. Regarding airflow, I do have a tornado of airflow with high end fans like Delta 152cfm :-)
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
12-08-2005, 01:15 AM
#4
XS Local
they will help a bit..
__________________
3dmark01 3dmark05
Heatware
12-08-2005, 01:43 AM
#5
X.I.P.
Heres with Gigabyte S754 mobo..on chipset and mosfets bond permanent with AS3 adhesive. It will help with heavy oc.
Sidewinder one of the best
12-08-2005, 02:02 AM
#6
Steak for Breakfast
12-08-2005, 07:17 AM
#7
Awesome stuff guys thanks!
If I put a picture of my mobo, can you please circle where you recommend me to put the heat sinks?
Here is the picture link:
http://prohardver.hu/html/lap/nf3_sh...2/dfi/mobo.jpg
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
12-08-2005, 10:25 AM
#8
I also got those microcool heatsinks on all the mosfets in my setup.
And I think they help a lot.
When I used my watercool setup the mosfets got very (and I mean very) hot,
but now with the heatsinks and the big typhoon installed they are at a more toutchable temp
(heatsinks on the mosfets and little airflow can do wonders)
I think without the heatsinks and airflow the mosfets would have melted of my motherboard with that prescott i'm running now
__________________
CPU: s478 Prescott 3.2E (E0) @ 4GHz
Board: Asus P4C800-E deluxe
RAM: 2x512mb Corsair PC3200XL (1:1)
Video: MSI 6800Ultra @ 425/1150
PSU: Fortron 550w
Case: Antec P180
Cooling: Big Typhoon
12-08-2005, 09:57 PM
#9
Aint No Real Gangster
i have the same mobo as you, and you will want to sink the mosfets to the left of the socket. they get extremely hot. ive measured them at over 70C with a thermal probe.
__________________
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale
2x1GB OCZ PC2-9200 FlexXLC
BFG GTX 280 OC2
Maxtor 6L250S0
Maxtor 6V300F0
Western Digital WD2500JS
Western Digital WD500AAKS
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Arctic Cooling S1
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
12-09-2005, 09:31 PM
#10
When the first generation P4 Prescotts came out, and folks were using them on the older generation Intel boards, well, as you can see, the mosfets supplying the socket got pretty hot.
In fact, if you look closely, pretty all new generation motherboards come with heatsinks on the socket power mosfets.
I've gotten good use from the thermalright nb-1, every now and then they go on sale for $10.
navig
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
