XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 12-06-2005, 12:47 PM   #1
shaolin95
shaolin95's Avatar
Radio Shack wireless thermometer or Vantec Nexus Multi-Function Panel for temp taking
What is a better choice for temp monitoring, specially of the RAM?
Here is the Vantec Nexus:
http://www.overclockercafe.com/Revie...FunctionPanel/
Here is the Radio Shack:
http://www.radioshack.com/product/in...71&tab=support
I supposed the Vantec is better since I dont need to open the case to test. It also has 3 temp probes.
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
shaolin95 is offline   Reply With Quote
Old 12-06-2005, 02:07 PM   #2
Thrilla
Steak for Breakfast
Thrilla's Avatar
Send a message via MSN to Thrilla
Well, depending on the your purpose, that Vantec looks very good. Also, that IR thermometer needs to be held at less than 1" from the heat source for accurate readings.
Thrilla is offline   Reply With Quote
Old 12-06-2005, 03:22 PM   #3
shaolin95
shaolin95's Avatar
1"?! Vantec it will be then, besides opening the case to use the RadioShack wasnt ideal either.
Regards
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
