XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 12-05-2005, 09:24 AM   #1
shaolin95
shaolin95's Avatar
Is the Radio Shack Infrared Thermometer a decent choice for PC?
Hi!
Just wondering if it works for PC temp taking.
Regards
Here is the link:
http://www.radioshack.com/product/in...71&tab=support
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
shaolin95 is offline   Reply With Quote
Old 12-05-2005, 09:50 AM   #2
Icy
XS_THE_MACHINE
Icy's Avatar
Send a message via ICQ to Icy
depends on how low it goes i think that one only goes from about -10 might be worth it depends on how low your system is going. have a look in the manual and see the temp range. apart from that i do like having no wires XD
__________________
[HEATWARE] Icy
Icy is offline   Reply With Quote
Old 12-05-2005, 10:12 AM   #3
shaolin95
shaolin95's Avatar
According to the manual it is -18 which is way lower than I expect to go in a long time since I am into air cooling and next step will be water and finally Ill get to the big leagues of phase.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Old 12-05-2005, 11:00 AM   #4
jinu117
-100c Club Member
It works okay for most use. Beam's focus is bit wider than what I would like though.
__________________
http://www.vapoli.com/Images/Forum/vapoli.jpg
Single Stage Work Logs
Originally Posted by killermiller View Post
Those ccb's will die if you look at them wrong.
heatware: jinu117
jinu117 is offline   Reply With Quote
Old 12-05-2005, 09:14 PM   #5
Bergo
Bergo's Avatar
i wouldn't bother buying an infrared thermometer for use with phase change, moost of the time you're concerned about the temp of something covered in insulation, and knowing the tempurature of the outside of your insulation isn't going to be particularily useful.
Bergo is offline   Reply With Quote
Old 12-05-2005, 09:19 PM   #6
shaolin95
shaolin95's Avatar
Actually is for my current air cooling...specially the memory which I have no sensor on so no way of knowing how hot it is. Heck, dont even know what temp is normal for this OCZ VX memory.
I think I am gonna skip water and will go with phase next year since I saw now that you can buy a $800 phase cooling sytem in a case , Vapochill. That is simple enough I hope.
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
