XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > General Computer Hardware > General Memory
Reply
Old 11-21-2005, 11:57 AM   #1
Diverge
Diverge's Avatar
2 x 1GB Memory Sticks - which run the coolest?
Of all the 2 x 1GB memory sticks out there, does anyone know which brands have IC's that run cool? I'm coming from Ballistix, which run hot, and require active cooling - and even with active cooling my sticks have gone bad. I'm gonna try to get a refund from newegg based on all the returns they get with the Ballistix, and want to switch to another brand with cooler running IC's that will do 250mhz minimum and can maybe do 270ish so it will match my dual opty.
I never really see people mention how cool the different IC types run, which is why i am asking
__________________
[DFI JR X58-T3H6] [i7 920 D0 3849A866] [12GB OCZ OCZ3B2000C9LV6GK] [HIS HD 5970] [SeaSonic X750 Gold ] [Windows 7 (64bit)] [OCZ Vertex 30GB x3 Raid0]
[Swiftech MCW30, Duniek DFI X58 Mosfet Block, D5 w/ Typhoon III] [Swiftech Apogee GTZ] [TFC 360 rad]
Diverge is offline   Reply With Quote
Old 11-21-2005, 01:23 PM   #2
GSKILL TECH
G.Skill USA Tech
GSKILL TECH's Avatar
all UCCC IC runs very cool becasue it only takes 2.5~2.6
__________________
Feel free to contact ustech@gskillusa.com or using our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
Check out our items on NewEgg
GSKILL TECH is offline   Reply With Quote
Old 11-21-2005, 02:47 PM   #3
Diverge
Diverge's Avatar
Thanks for the reply G.S Tech, i'll keep that in mind if i can get a refund from newegg
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
