XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 11-18-2005, 05:11 PM   #1
shaolin95
shaolin95's Avatar
Are 31CFM enough to cool down OCZ PC4000VX at 3.5v or more?
Hi!
Thats the amount of air my 2x40mm right over the the ram slots deliver (31cfm). According to GEIL thats enough so I assume OCZ should be the same. I asked them and they say it was but I wanted to hear from user experiences. Besides that my case is a tornado of airflow thanks to my Scythe Ninja and its Delta 120mm fan at 150CFM plus around 8 other fans working to maximize air flow.
Regards
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
shaolin95 is offline   Reply With Quote
Old 11-18-2005, 05:16 PM   #2
craig588
Xtreme Guru
craig588's Avatar
Send a message via AIM to craig588 Send a message via MSN to craig588
That's fine. I don't even hook my fans up to a CFM meter. I just drop a regular 80MM or two on the memory and assume it's fine. It's never given me a problem and my sticks are essentially ambient.
3.5V is nothing, small fans will be fine for that.
Where did you buy your CFM meter? I'm kind of interested in purchasing one.
__________________
For those of you about to post:
craig588 is offline   Reply With Quote
Old 11-18-2005, 05:50 PM   #3
shaolin95
shaolin95's Avatar
Actually I dont have a CFM but I bought my fans at Sidewinder.com and the Deltas are very accurate with their CFM rating unlike most brands. Trust me thise 150CFM Delta feels like a tornado...I knew it was going to be fast (and loud) but not that fast. I just wonder how that 220CFM one should feel! I wanted that one but I wanted to stay at 1amp (12v).
Regards
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Old 11-18-2005, 07:03 PM   #4
craig588
Xtreme Guru
craig588's Avatar
I have two of those 3 amp deltas. They blow on my condenser, push/pull style.
They arn't too loud, about the volume of a large box fan on high. (I broke my dB meter so I don't have exact numbers)
__________________
Old 11-18-2005, 07:26 PM   #5
shaolin95
shaolin95's Avatar
Maybe I will buy one for my CPU in the future just to see what difference it makes. I which the deltas came in different colors or with leds :-)
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
