XtremeSystems Forums
Reply
Old 11-16-2005, 06:11 PM   #1
One_Hertz
One_Hertz's Avatar
Send a message via MSN to One_Hertz
Running Iwaki on lower voltage?
Is it possible? Like running a fan at 7v is it possible to make a wmd 20rlzt iwaki to run quiter at like 60-70 volts or so (115 normal)?
One_Hertz is offline   Reply With Quote
Old 11-16-2005, 06:30 PM   #2
Bloody_Sorcerer
beefin' it up!
Bloody_Sorcerer's Avatar
Send a message via AIM to Bloody_Sorcerer Send a message via MSN to Bloody_Sorcerer
probably depends on what kind of control electronics there are; as I have not dissassembled mine own, I don't know. Anyone have pictures of the guts of an iwaki and/or know the answer to the question?
__________________
HD 5850 inc!
Bloody_Sorcerer is offline   Reply With Quote
Old 11-16-2005, 06:35 PM   #3
MaxxxRacer
Xtreme X.I.P.
MaxxxRacer's Avatar
Send a message via AIM to MaxxxRacer Send a message via MSN to MaxxxRacer
the speed of the motor is dependant on the hertz of your local power company (60 for america)
so if u can figure out a way to adjust the wave form to say 30hertz you can run ur pump slower..
but tbh i dont know what effect changing the voltage will do.
MaxxxRacer is offline   Reply With Quote
Old 11-16-2005, 06:36 PM   #4
EnJoY
XIP
EnJoY's Avatar
Send a message via ICQ to EnJoY Send a message via AIM to EnJoY Send a message via MSN to EnJoY Send a message via Skype™ to EnJoY
Since when were Iwaki's loud? Assuming you mounted it with a sound dampening/vibration hampering material, it should be very quiet.
EnJoY is online now   Reply With Quote
Old 11-16-2005, 06:39 PM   #5
HelloIDistance
Yea, I have the same brand Iwaki mounted on a pad and its pretty quiet for a pump.
__________________
Opteron 148 CAB2E 0604 (255*11 2.8Ghz 1.4 Vcore)
DFI LANPARTY UT nF4 Ultra-D (Rev AD0)
2x1 GB Mushkin eXtreme Performance DDR 500 (255 3-4-3-8)
EVga 7800GT - Waiting for new cooler to OC
OCZ Powerstream 520 watt
HelloIDistance is offline   Reply With Quote
Old 11-16-2005, 07:05 PM   #6
Bloody_Sorcerer
beefin' it up!
hmm, makes me curious. I don't like me when I'm curious!
wonder what the effects of running it at say 70hz would be... aw crap. I'm gettin really curious. might just have to make a project out of this
__________________
HD 5850 inc!
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
