XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 11-14-2005, 05:20 PM   #1
shaolin95
shaolin95's Avatar
urgent! Cant remove the HS from my CPU
Hi!
I am trying to remove the HS and have been moving it (rotating back and forth) and nothing. Can I use a blower to heat it up a little bit?
UPDATE! The hair dryer worked! Thread can be closed now.
__________________
Main PC
*CPU: i7 920 DO @ 4.1Ghz 1.35v HT On
*CPU Cooler: Noctua NH-D14 SanAce/Scythe/Delta
*Mobo: Evga X58 SLI
*RAM: 3x2GB OCZ DDR3 OCZ3P1600LV6GK 7-7-7-24 1.65v
*Video Cards:XFX GTS250 Physx card & Evga GTX 295 dual pcb
*Sound Card: X-Fi Prelude| Speakers: Strata Mini + ELT 525s (AV123)
*PSU: Corsair HX1000W
*Display:Samsung 2233RZ 3D Vision!!! | Mitsubishi 60" DLP (3D) 3D Glasses (stunning!)
*Windows 7 64Bit on GSkill Falcon V1 SSD 64GB
*Case: CoolerMaster HAF932
*Others: Logitech MX518 | SteelSeries Pad | Ratzpad GS | Logitech G15
HTPC Rig
*Case: Aspire X-Navigator
*CPU: Intel E8500 OCed 4.2Ghz (8.5x495) 1.35v bios
*Cooler: Scythe Ninja first edition with Yate Loon
*Mobo: Asus p5K-e Wifi bios 1202
*RAM: 2x1GB Crucial Tracer@495fsb(1:1) 4-4-4-12
*Video Cards: ATI HD2600 Pro
*Speakers: Rocket HT & MFW15 (AV123.com)
Cameras: Pentax K20D & K100D
shaolin95 is offline   Reply With Quote
Old 11-14-2005, 05:32 PM   #2
fullup3
fullup3's Avatar
use a hairdryer, just keep it about 6 inches away, and constantly wiggle the hs so that when it gets warm it will pull free.
I have had this happen before also.
__________________
X2 3800+ - IHS @ 2950 1.424v, 3000 1.488v
LDBHE 0601 TPMW "N" cooled w/ aquagate mini R120
eVGA 7900gt vanilla @ 625/1700 1.3vmod
DFI LanpartyUT nF4 Ultra-D (bios 702-1)
2 gb g.skill HZ 3:4:3:6 @ 250
fullup3 is offline   Reply With Quote
Old 11-14-2005, 05:33 PM   #3
shaolin95
shaolin95's Avatar
Just read your reply. Yes it did work. I was getting desperate!
__________________
Main PC
*Mobo: Evga X58 SLI
HTPC Rig
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
