XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 11-08-2005, 09:58 AM   #1
Coyote
Coyote's Avatar
Send a message via ICQ to Coyote Send a message via AIM to Coyote Send a message via MSN to Coyote Send a message via Yahoo to Coyote
Is this vacuum pump any good?
Hi, ive been looking foward to get this vacuum pump, and i wanted to know if its good for this kind of task.
here is the datasheet of the pump. (spanish and english)
http://www.buenosaires.ansal.com.ar/...dfs/792202.pdf
any coments are welcomed.
Coyote is offline   Reply With Quote
Old 11-08-2005, 12:04 PM   #2
RussC
Im sure that pump is sufficient.
RussC
RussC is offline   Reply With Quote
Old 11-08-2005, 04:09 PM   #3
wdrzal
I am Xtreme
wdrzal's Avatar
I seen that pump marketed under the "cps" brand here in the states.
wdrzal is offline   Reply With Quote
Old 11-08-2005, 11:01 PM   #4
Coyote
Coyote's Avatar
isnt it 50mmhg too little? thats the thing that worried me.
Old 11-08-2005, 11:26 PM   #5
Gray Mole
Gray Mole's Avatar
The Yellow Jacket pump I've got will pull to 15 micron.
That one is 50 micron.
50 micron is just fine
Water boils at about -45c at 50 micron pressure. No problem there.
It's about -55c with the 15 micron mine will pull, but really there's no reason why that one won't do the job just fine.
Gray
__________________
Nearly back from the dead.
Gray Mole is offline   Reply With Quote
Old 11-08-2005, 11:30 PM   #6
Coyote
Coyote's Avatar
i see, thx for the info.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
