Originally Posted by calcal
this board does not support this chip. I know for a fact that the abit 865/875 do though
If it's the same chip that I have (3.06 533MHz M) then it does. I ran with mine for a bit, but it defaulted to the 12x, and I got bored with it (It is an E.S. though). If definately only worked with one of the BIOS though. I had to keep flashing back to use it, as I was playing with the new BIOS to try and see if they figured out how to utilise the 23x.
Are you sure the IC7 series works with it? I had an IC7-Max3, and I don't remember it POSTing with it, although it was a while ago so it may have done...
