XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 09-26-2005, 03:11 AM   #1
JoeBar
Xtreme Mentor
JoeBar's Avatar
Expected oc from P4 630?
I'm in the market for a P4 630 and would like to know what's the expected oc from a 630 on air? I'm using a Zalman 7700Cu (for now).
Also are there any particular steppings i would look out for better oc?
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
JoeBar is offline   Reply With Quote
Old 09-26-2005, 03:28 AM   #2
IluvIntel
IluvIntel's Avatar
JoeBar, Look at my signature, that is what I can achieve with ambient temp of 23-24 C using Thermaltake Big Typhoon heatpipe/fan cooler in full tower case. I can bench at 4.3ghz on air with same ambient temps and Vcore of 1.62.
All day running is good for 4.2ghz @ full load, as far as steppings are concerned there is only one at the moment from Intel, it is N0 series for 6xx.
They should be putting out 6x1 series pretty soon with support for Virtualization Technology on single core chip.
Link is here: Intel VT tech
__________________
Signature? are you kidding? with new stuff coming out every day, why bother ?
IluvIntel is offline   Reply With Quote
Old 09-26-2005, 09:09 AM   #3
JoeBar
Xtreme Mentor
JoeBar's Avatar
Thanks for your thorough answer!
Same results with u has a friend of mine using a 630 with a Zalman 7700Cu, so i believe that 4.0ghz (that's my goal) is achievable.
Also do u like your P5WD2? I've read many good reviews on it but i would like user info too cause this m/b i'm going to buy.
I'm conserned about a restart prob (shutdown instead of restart) prob that occurs beyond a certain oc. I've read it in a review and also my friend, who uses a P5LD2, has it. Have u experienced it?
__________________
Watercooling setup:
Old 09-28-2005, 05:24 AM   #4
JoeBar
Xtreme Mentor
JoeBar's Avatar
I finally tried out my 630 but seems that i'm not so lucky.
It maxes out @ 4.0ghz but with 1.65+ vcore. For everyday use i'm @ 3.9ghz with 1.55v. Cooler is Tt big typhoon.
Also the restart prob do exist beyond a certain oc which is very annoying...
__________________
Watercooling setup:
Old 09-28-2005, 09:18 AM   #5
ROCKSOLID
ROCKSOLID's Avatar
Mine do 4.00Ghz default vcore. Never try more ( for now ;-) ). SL7Z9 from china. Works as a rock :-).
__________________
Workstation P5K WS - Q6600 @ 3.20 (400x8) 1.3V - Zalman 7700Cu - 2GB Kingston HyperX DDR2800 4-4-4-12 1.85V 1:1 - X800GTO - Dual TFT 17" -
Gaming P5W DH Deluxe - E6600 @ 3.00 (333x9) 1.25V - Zalman 7700Cu - 2GB Corsair TwinX DDR2667 4-4-4-10 1:1 - ASUS 8600GT Silent
Server P5WD2 Premium - 940 @ 3.20 (267x12) 1.35V - Zalman 7700Cu - 2GB Kingston HyperX DDR2533 3-3-3-8 1:1 - Ati Rage II PCI - 1,2 TB Storage
Mobile Compaq nc8430 Laptop + Qtek S200@WM6
ROCKSOLID is offline   Reply With Quote
Old 09-28-2005, 10:50 AM   #6
charlie
THE GENERAL
charlie's Avatar
Mine runs 24/7 @ 3800mHz and 1.5v
Higher than that and it just get's TOO hot.
C
charlie is offline   Reply With Quote
Old 09-28-2005, 08:35 PM   #7
amd3001
mine does 4ghz at 1.41v. 55c load temps. used to run 4200 with 1.43 volts but wont do it now even with 1.45v. I can live with 4ghz at 1.41v.. Its not the best overclocking chip but certainly is not the worst.
amd3001 is offline   Reply With Quote
Old 09-29-2005, 05:39 AM   #8
JoeBar
Xtreme Mentor
JoeBar's Avatar
Seems that 4.0ghz is a trend for these cpus. I was a bit unlucky...
__________________
Watercooling setup:
Old 09-30-2005, 07:48 AM   #9
IluvIntel
IluvIntel's Avatar
C'mon, are we kidding ourselves here !
at 4.2ghz from 3ghz is approx 41% overclock on Air ! very stable too. What the hell is wrong with that ?
It seems a lot of visitors to this site are spoilt rotten and expecting BIG things from bottom of the range chips...
I don't know about prices around the world, but here in Oz - these chips can be had for only A$270 approx. Bargain !
The biggest problem I find with this chip is not being able to use 14x multi, from what I hear you got to use 660 or 670 to get that happening.
If you use Corsair's 5400ULs or the 8000's on P5WD2 mobo and use 3:5 with tight as stable timings - great memory efficiancy really starts coming on, especially around 933mhz and up. In Everest and Sandra you cream everything as long as FSB is at least 280mhz +.
__________________
Old 10-02-2005, 04:32 AM   #10
JoeBar
Xtreme Mentor
JoeBar's Avatar
I didn't say that 3.9ghz that mine can reach is a minimal oc. I just wanted to get to 4.0ghz. No prob though.
These chips are really nice!
__________________
Watercooling setup:
Old 10-02-2005, 04:38 AM   #11
amd3001
IF a 600 series doesnt do 4ghz I would get rid of it.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
