09-23-2005, 11:53 AM
#1
Going mATX what mobo?
whats the best mATX mobo out there right now?
i found that asus and gigabyte has a nfoorce 4 mobo no sli or so but pcie atlease!
so im heading matx so what mobo to choose?
i still want some oc options so it should not be totally worthless on that front!
another question about m-atx, can i use my standard psu or do i have to use the one that comes with the matx chassi?
09-23-2005, 12:09 PM
#2
You will need a micro-atx PSU, unless yours fits in the micro-atx chassis. (I highly doubt it will.)
09-23-2005, 12:11 PM
#3
ive been using the ecs rs480m for around 5 or 6 months. its an ati radeon xpress 200 board with ati southbridge. very stable board. never had a problem with it. now running a 3500 venice, 2x250g maxline 3 raid0, benq 1640 dvdr(same as plextor), 6800gt, wifi, 2x512nb pqi turbo tccd. overclocking is limited, vcore only to 1.45v, vdimm to 2.7v(overvolts to around 2.78v, good for tccd or tcc5). has multis. onboard sound(average), onboard x300 vid. there are some modded bioses around for higher vcore, vdimm to 2.9 or 3.0, extra mem timings, etc. been running in an x-qpack for 5 or 6 months, never had a single problem, usb works fine(a problem with a lot of boards using ati southbridge) u should be able to pick one up around $70 or so. good luck.
very truly yours,
politenessman
ps the x-qpack comes with a 420 volt psu that runs all that stuff, including an overclocked gt, no prob.
number 1, all cpus 3000mhz and under, all gpus, all drivers, all os's
http://service.futuremark.com/compare?3dm05=1246973
09-23-2005, 05:55 PM
#4
And from what I've seen the onboard GPU is really very good. Good enough for HTPC or gaming some not too heavy games @ 800x600.
__________________
The world vs the USA: The whole world hates you!
USA: Why?? Why does the whole world hate us?
The world: Because the whole world hates you, and you don't even know why!
09-23-2005, 05:59 PM
#5
I think a good opcion would be the "msi Rs480" i think it is, with Ati xpress 200 chipset.
__________________
Tbred 1700+ @2400mhz (RBX Watercooled)
Abit Nf7-s v2.0 (detoned lan)
2x256 Crucial Ballistix Pc3200@2-2-2-5 1t
GeForce 2 mx400@Vatec Iceberg@285/215
Maxtor 9Gb
450w Generic PSU
09-23-2005, 08:16 PM
#6
YouTube Addict
Dead Wrong micro-ATx uses the same PSU connections as any ATx board!
Itx is what needs different connections...
on a side note wait 3-5 weeks to see if DFI/MSI have any nVIdia mATX boards coming out.. if not
get the RX480 MSI if you can get your hands on one.. they are kind of hard to come by....
09-23-2005, 08:49 PM
#7
Unbanned for Life
He is dead right...
He said fit in the case... NOT connect to the mobo... matx form factor PSUs are a different size, though the connectors are the same....
09-23-2005, 09:36 PM
#8
YouTube Addict
woops, I might have missed that...
My thought is put it in a much larger case for better airflow.. and more space for the PSU...
09-23-2005, 09:44 PM
#9
Another vote for the 6100 boards.
09-24-2005, 12:36 AM
#10
so the msi with xpress200 chipp is the best to pick?
where can i find that bios?
how good is the psu in the x-qpak?
how is the msi board performance against nfoorce4?
how big is the Aspire X-QPACK inside? is there any chanse to fit in a x800gt with an ati silencer 4 and a slk948-u on the cpu?
09-24-2005, 12:52 AM
#11
Xtreme Cruncher
wrong too, itx can use every atx-psu you have.
__________________
E2160 @ 360x9, max 390x9 watercooled
GA-P35-DS3
Cellshock D9GMH @ 545mhz cl5-5-5-5-15
Palit 7300gt 500/1000 @ 780/1600 watercooled
09-24-2005, 12:55 AM
#12
ust gotta ask this, can i use my Hiper 580w to the Aspire X-QPACK?
09-24-2005, 02:58 AM
#13
Snowman,
Standard sized psu's fits that case if you bend it slightly and also remove the atapi unit. I use external atapi anyway so it doesn't really matter.
The 600W Powerstream is slightly bigger than standard actually.
09-24-2005, 03:01 AM
#14
atapi?
what motherboard are you using?
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
