09-21-2005, 05:35 AM
#1
Xtreme Mentor
Good 3500+ steppings?
I want to upgrade my 3200 winnie (tops @ 2550mhz) for a 3500+. I know that it's best to buy a venice but any good steppings?
__________________
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.35GHz (20 X 217mhz) WC'ed
3 x 2GB G.Skill Trident 1600 @ 1740MHz (7-8-7-20-1T)
Asus 4870X2 @ 850/950MHz WC'ed
150gb Western Digital Velociraptor | 2 x 320gb Western Digital Caviar SE16 Raid0 | Seagate FreeAgent XTreme 1.5TB esata
Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
MountainMods UFO | Zalman ZM-850HP psu
Watercooling setup:
1st loop -> Radiator: ThermoChill PA 120.3 | Pump: Laing DDC Ultra with Alphacool top | CPU: Swiftech Apogee XT |Chipset: Swiftech MCW-NBMAX | Tubing: PrimoFlex 1/2" Pro LRT
2nd loop -> Radiator: XSPC RX240 | Pump: Laing DDC Pro with Alphacool top |GPU: EK FC-4870X2| Tubing: PrimoFlex 1/2" Pro LRT
09-21-2005, 02:28 PM
#2
I don't think this belongs in Xtreme Overclocking
09-21-2005, 02:33 PM
#3
I think LbbLE is pretty good,...Mines stable up to and including 2.9 ghz on air .... (1.7 volts though, but cool enough)
__________________
E6600
P5W DH deluxe
OCZ EL PC6400
X1900XT's
09-21-2005, 02:38 PM
#4
Xtreme 3DTeam Member
This is a textbook AMD section post. Trust me, PM a mod and ask them to move it there, you will get 10x the responses.
09-21-2005, 02:43 PM
#5
LoL, and probably better ones then mine as well hehe...But then again,...I LOVE chaos!
__________________
E6600
P5W DH deluxe
OCZ EL PC6400
X1900XT's
09-22-2005, 12:51 PM
#6
 about 99% of BPs are lbble
best stepping: 0517 Ep*w or old BW 0519 - 0521
09-22-2005, 01:18 PM
#7
Administrator
I'm moving this topic to the AMD section, as it doesn't really belong in the XOC section.
__________________
Rig #1
Gigabyte UD3P Rev. 1.0 Bios F4
E8600 @ 4400Mhz, 1.296V
2x2Gb OCZ1066 LV Blade
BFG GTX280 OC
Coba Nitrox 750W
Watercooled with HK 3.0 CU, EK-FC280GTX, PA120.3, Laing Ultra with XSPC top
Rig #2
DFI UT P35-T2R (0317 bios)
E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
2x2Gb Chaintech Apogee GT PC2-8500
Powercolor 4870
Corsair 520HX
Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
Originally Posted by Movieman
I've got Supermicro boards that lasted longer than one of my marriages!
09-23-2005, 05:30 AM
#8
Xtreme Mentor
I finally got a LLBLE 0521 CPGW, but it seems that i'm not among the lucky ones...
It tops @ 2550mhz with 1.55v.
__________________
Watercooling setup:
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
