XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Graphx Vmods
Reply
Old 09-18-2005, 01:43 AM   #1
Snowman89
X800gt vmod?
im looking for a vmod for my x800gt, the pics i post i borrowed from Nephilim's review (http://www.xtremesystems.org/forums/...87#post1045987)
if you mark spec chipps i can check what it is
Snowman89 is offline   Reply With Quote
Old 09-18-2005, 02:41 AM   #2
persivore
Xtreme Vmod mod
Send a message via MSN to persivore
The card looks like its got a similar layout to the X850 series of cards. You should be able to use this guide for the mods
persivore is offline   Reply With Quote
Old 09-18-2005, 03:42 AM   #3
Snowman89
yeah i tryed the pencil mod for vgpu but it didnt matter how much i painted it the resistans didnt change, will try the vdd soon, whats igpu?
Old 09-18-2005, 03:44 AM   #4
persivore
Xtreme Vmod mod
Igpu is the overcurrent/OVP mod for the Vgpu. You shouldn't need it unless you're running 1.7v+
Old 09-18-2005, 06:32 AM   #5
Snowman89
okey, doesnt care how much graphit i add the resistans doesnt change on the vgpu mod, any other ideas?
would the same mod work if i did it the solder way?
Old 09-19-2005, 09:35 PM   #6
megatron
megatron's Avatar
Maybe ur using wrong type of pencil? I think u need a pencil with graphite in it.
megatron is offline   Reply With Quote
Old 09-19-2005, 10:29 PM   #7
Snowman89
its not the pencil...
used the same pencil to the vdd mod and it works
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
