XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 08-24-2005, 07:44 PM   #1
Arkangyl
Arkangyl's Avatar
Crazy improvement over time
Okay, so ignoring my posts and thread moaning about lackluster RAM bandwith I decided to do a little testing.
First I wanted to see if my HTT bus was in any way holding me back, with a lower CPU multi and a 3x LTD I went to work
http://valid.x86-secret.com/show_oc.php?id=34707
365fsb, with a 3x LTD I have a 1095mhz Hypertransport bus.
stock voltage everywhere but on the RAM (set at CPU/18 thou), stock NB cooler (with AS5)
when i got the board for Christmas it was barely stable @ 300fsb with low everything else, now 300fsb seems toally stable and 365 is my new max. Interestingly thou, with a 2x LTD the fsb wouldn't get to 365; seems a 3x LTD is my Neo2's sweet spot.
With my newfound frontside-bus speed i decided to see what my CPU would do. Stock voltage, stock cooler (with AS5)
http://valid.x86-secret.com/show_oc.php?id=34704
2.5ghz, last time i tried stock everything like this I crashed at 2.2ghz :p, this time I crashed just shy of 2.6ghz. I'm not sure how stable 2.5ghz is ATM but I'm quite pleased at the apparant burn in results.
vital stats ::
3000+ Winchester
0xFF0 DH8-D0
CBBFD 0442TPMW
Malaysia
MSI K8N Neo2 Platinum (yea, still AGP :P, I've got a 6800 Ultra that does 450, 1.22 stock air and 490, 1.26 water though)
1.37b mod BIOS
didnt write down chip info
Now, time to get my watercooling setup I know it's a tad old but figured I'd post my OC results with this stuff in case anyone is buying one used.
__________________
CPU:: i5 750
GPU:: GTX260-216
MB:: EVGA p55 SLI
RAM:: 4gb DDR3-1600
AUDIO:: Xonar Essence STX
Arkangyl is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
