XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Bandwidth
Reply
Old 08-23-2005, 07:16 PM   #1
Arkangyl
Arkangyl's Avatar
Cannot get 1T to run on my RAM, regardless, help
Hokay, so here's the story.
I wanted a gig of ram so I bought one of jinu's gig's of Mushkin Blue, he had em at 2-2-2 240mhz ish, that's not even the real problem atm, just some backround on the RAM.
My rig is as in sig, supposedly I've modded the motherboard to use the 3.3v line to power the RAM, everything looks just dandy.
the ram runs 2-2-2-8 200mhz just fine, game & all
in Everest I get (consistantly) the low 4x00 mb/s range
I am definatly in dual channel
with 2-3-3-8 I get 5768 mb/s
W-T-F?
is this a sign that my vmod has been an utter flop or am I missing something?
thanks guys
__________________
i7 920 @ 3.7ghz || Bloodrage || 6gb Pi Black || GTX 260+ || Xonar STX || 300gb VRaptor || U2-UFO
PA 120.3 & MCR-220 || DDC-3.2 XSPC || EK LT|| XSPC FC GPU
Arkangyl is offline   Reply With Quote
Old 08-24-2005, 08:29 AM   #2
enzoR
XS Intel News & DČOL enhanced
enzoR's Avatar
try sandra
__________________
enzoR is offline   Reply With Quote
Old 08-24-2005, 10:51 AM   #3
Lood007
Lood007's Avatar
Send a message via AIM to Lood007
Do the tighter timings cause your motherboard to default to 2T command rate?
Does the mem (when at 280 and tight timings) pass memtest and prime overnight?
Also, check laetncy in everest and compare those values.
__________________
Q6600 G0 at 3.5 GHz 1.30v on DFI P35-T2R
4GB OCZ PC2-9200 Reapers
150GB WD Raptor, 2xWD 120GB RAID-0, 3x320GB HDD
BFG 8800GTS OC at 675/2100
Danger Den Based Water Cooling: TDX-775, 8800GPU, DD NB Block on Thermochill PA120.3 Radiator w/ DD 12V Pump
OCZ GameXStream 850W
MountainMods U2-UFO 18" Cube Case
DELL 2405FPW 24" Widescreen LCD
RME-Audio Fireface 800 based audio production
Lood007 is offline   Reply With Quote
Old 08-24-2005, 11:54 AM   #4
metro.cl
Xtreme X.I.P.
metro.cl's Avatar
Send a message via MSN to metro.cl
maybe is something like what happened with nf2 runing 2-2-2-5 vs 2-2-2-11 maybe it causes the memcontroler to re-read info or something like that making lower latencies perform worst
metro.cl is offline   Reply With Quote
Old 08-24-2005, 01:43 PM   #5
Arkangyl
Arkangyl's Avatar
so you think 2-2-2-5 might fix things? I'll give that a try (along with sandra) in a minute.
and as far as I know 2-2-2 doesnt default a T2 command rate, it's the neo2 Plat, pretty popular board and I've got to believe that if there was a T2 issue I'd have heard about it
__________________
Old 08-24-2005, 02:09 PM   #6
Lood007
Lood007's Avatar
There is no issue with the board, but if the BIOS setting is at Auto, the board will do whatever it wants. Set it yourself and see if there is any difference.
__________________
Old 08-24-2005, 02:13 PM   #7
Arkangyl
Arkangyl's Avatar
here's the deal
I have the BIOS set to T1, forced
with 2-2-2-8 and 2-2-2-5 timings Sandra is reporting me as having a T2 command rate.
BIOS 1.36B
2-3-3-8 stays T1, I'm gonna try 2-3-2-8 and then A64Tweakering it.
I'll post back in a bit
edit, update ::
I've tried most everything I can think of
2-3-3-8
2-3-3-11
2-3-2-8
2-3-2-11
2-3-2-6
2-3-2-5
2-2-2-5
2-2-2-8
2-2-2-11
2-2-2-6
All of them are using a 2T command rate; it's DEFINATLY set to 1T in the BIOS.
the only thing I havnt tried is setting a 2T or AUTO command rate in the BIOS and altering it in A64Tweaker. Oh well, time to try that. If it fails; it's flashing time
__________________
Old 08-24-2005, 03:31 PM   #8
RyderOCZ
OCZ Memory Guru
RyderOCZ's Avatar
Are you referring to what Sandra says about 2CMD.....it does it on many AMD systems....just a "bug" if you will...if you set 1T in the bios...then your memory is running 1T
__________________
Problems with your OCZ or PCP&C Product? PM or E-mail Me
OCZ and PCP&C Support Forums - Click Here
RyderOCZ is offline   Reply With Quote
Old 08-24-2005, 04:15 PM   #9
Arkangyl
Arkangyl's Avatar
well that helps :P
still, I'm only getting 5300 mb/s with 2-2-2-5 200mhz
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
