I'm currently running a MSI K8N Neo2 Platinum with the vDIMM = 3.3v line mod (using Mushkin Blue UTT). ATM this is working out alright but I have dreams of more vDIMM.
I know one option is to raise the 3.3v line's voltage.
Another would be a DDR booster.
however I like to do this stuff myself
What i want to do is create a circuit that takes the 5v line from the 24 pin connector (sanded down the 20 pin female on the board so i can just put a 24 pin in there :P ), resist it down to 4v. Throw a cap or two to keep it clean and then add some sort of VR to adjust the voltage.
To do this I need to know first and foremost; what will the amp draw on the 5v line be?
Secondly, does anyone have any good links to similar projects?
thanks
Ark
