08-03-2005, 04:59 PM
#1
CAK 38 Evap
08-03-2005, 05:30 PM
#2
Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
__________________
My Rig:
Q6600 2.4Ghz@2.9Ghz Custom Liquid Cooling
ATI X1950XTX 512mb DDR4
MSI 975X Platinum PowerUp Edition
2gb Kingston Hyper-X DDR2 667
Sound Blaster Audigy2
2 IDE HDD, 2 SATA HDD
LG DL16XDVD Writer,52X CDROM
OCZ 520Watt PSU 33Amp +12v
Thermaltake Xaser III case
Logitech Z560 4.1 400watt Surround Sound
3Dmark03-21112
3Dmark05-12154
3Dmark06-8054
08-03-2005, 05:40 PM
#3
nice going bro! lots of surface area on that thing.
08-03-2005, 05:52 PM
#4
Nice! Show us some results with it soon; I'm curious to see how it performs.
08-03-2005, 06:32 PM
#5
lol. i was staring at the pictures for like 5 mins trying to figure out why the end of the suction line was squeesed together a bit but now i understand
it looks like it will do a nice job and looks alot nicer than any evap that i've built. cant ait for the results
08-03-2005, 07:09 PM
#6
Looks great, but seems a litle big. What the base dimensions ?
__________________
Q9550 EO @ 4.1
Asus P5Q Deluxe
4 Gb DDR2 Gskill
2xVelociraptors 300 gb Raid 0
Sapphire Vapor 4870 1Gb
PCP&C 750w silencer psu
08-03-2005, 07:10 PM
#7
I am Xtreme
Hmmm... Its awesome and you giving me an idea...
__________________
NoL: gom gom gom
Gomeler: om nom nom nom
08-03-2005, 07:34 PM
#8
thx ppl.
marvin, the base is 60x45mm. the extra 7,5mm in each side, is for the mounting device made of tivar.
08-03-2005, 09:42 PM
#9
Very very neat job!
Should make a good evap, but how I about oil problem?
The evap is so spacious makes it more possible for the oil to stay there instead of return to suction line.
Can't wait to see when it's mounted to real CPU
__________________
Intel Pentium 4 506 China SL8J8 2666 MHz @ 5000 MHz| ABIT AS8-V (i865PE) |
Mushkin PC3500 2x256MB | ABIT ATI R9550 XTurbo (790/405) | Twin R-502 Single Stager
08-03-2005, 11:06 PM
#10
Originally Posted by kemod
Very very neat job!
It looks like the suctionline extends >80% of the way to the base of the thing, so it'll probably get sucked up before too much can pool.
08-04-2005, 07:10 AM
#11
HVAC/R Engineer
Cool EVAP// What do ya call it "ICE CUBE" ??
Can't wait to see results..
08-04-2005, 07:13 AM
#12
ln2nl
What a nice design.. hope it will perform like it lookes
__________________
*EDITed by IFMU*
Signature Removed by XS Staff for not following XS Policies
Forum Policies
08-04-2005, 07:17 AM
#13
sweeeeeeeeeeeeeeeet design and construction =]
is it similar to the attachments you can get on household vacuum cleaners to get into the crevices?
lol =]
08-04-2005, 07:30 AM
#14
thx for your comments ppl.
ICE CUBE it is then
08-04-2005, 07:38 AM
#15
Xtreme Legend
the sucktion line picking up liquid at the bottom of the fins is a bad idea
08-04-2005, 09:42 AM
#16
actually i would like to pick up gaseous refrigerant, not liquid
08-04-2005, 10:42 AM
#17
I used a similar evap on one of my first builds. I modded an old copper HSF like that. Didnt like it that much tough....
__________________
cool cool cool!
08-04-2005, 04:28 PM
#18
what HSF you used?
08-04-2005, 05:33 PM
#19
Looks efficient. My first thought was that the suction line extending to the bottom was a bad idea but I can see that that configuration would force the refrigerent to flow through almost all the fins. I wonder what would happen if you put a separator between the inner and outer fins forcing the flow to go down to the bottom through the outer fins and back up to the top through the inner fins, negating the need for the suction line to extend to the bottom.
What I can see happening here though is the fins being continually wet, which would make for much better heat transfer than just superheated refrigerant vapor flow over the fins.
08-04-2005, 06:07 PM
#20
very nie hope to see some results
__________________
afireinside on AIM :: I just about got walked in on because my mom wanted to show me her website :|
IYP :: hahaha
afireinside :: friggin ruined my night
VOTE YES FOR A MOBILE PHONE SECTION HERE
Need a new screen? Go to THE LCD BUYERS GUIDE
08-04-2005, 07:00 PM
#21
Im curious. Hurry up and test it!  Awesome work BTW...
08-04-2005, 08:00 PM
#22
i though doing that, but the suction pipe barely fitted there, i couldnt fit 2 separators there
08-04-2005, 08:09 PM
#23
Well all I can say is that you are well off the beaten path of evap designs. Allow me to join the corus of 'show us the results'.
08-04-2005, 08:13 PM
#24
well, in part that was one of the first thing i wanted to do of this project.
join the chorus, im the first one singing in this choir
08-04-2005, 08:35 PM
#25
Originally Posted by Coyote
what HSF you used?
IIRC it was an old Therlmalright copper HSF.
__________________
cool cool cool!
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
