XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 12-27-2002, 10:38 AM   #1
tedderms
Please help with Evaporator ...
I am in the planning stage of my phase change cooling project. My working Plans are to use either a +8000btu window AC unit or a Dehumidifier atleast 40 pint for the basics. I am thinking that R290, propane, is the best better for the price. I am not afraid of explosions with propane, I have worked around it a good bit. Alot of the details are a little fuzzy but they can be worked out with time. I am lucky in that I have a friend thats old job was HVAC, now computer Tech.
What I really want to asked about at this time is the Evaporator. I am planning on building this in two Rack mount cases. The cooling gear will go in the the lower case. To help with Condensation I was planning to mount the mother board upside down on the top of the case. Now all I need is to work out a plan for a evaporator that chills the top of the block well.
Any help is welcome. Thanks for your time.
tedderms is offline   Reply With Quote
Old 12-27-2002, 10:44 AM   #2
FUGGER
Xtreme Owner
FUGGER's Avatar
Send a message via MSN to FUGGER
What I did was get a Volcano 7+ and attempted to fashion it into a evaporator block.
Somehow I shortened my plans and just dropped the whole evaporator in my water bucket and left my waterblock on the CPU.
Im not sure if using a existing heatsink will aid you but it will cut corners when trying to figure out how you will mount the thing.
__________________
Intel Core i5 661 @ 4.6Ghz
Gigabyte P55A - supports 32nm now
Gigabyte GTX 260 SOC
Corsair Dominator 8GB 2200C8
Intel SSD RAID 0
http://valid.canardpc.com/show_oc.php?id=925582
FUGGER is offline   Reply With Quote
Old 12-27-2002, 10:44 AM   #3
FUGGER
Xtreme Owner
FUGGER's Avatar
Oh yeah, welcome to Xtremesystems.
__________________
Intel SSD RAID 0
Old 12-27-2002, 10:58 AM   #4
tedderms
humm
If a water block would work well that would make things easier, but with this being a upside down Horizontal system I am concerned. I am willing to get the evaporator custom milled.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
