XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 07-07-2005, 11:49 PM   #1
bachus_anonym
Corsair Engineering
bachus_anonym's Avatar
Send a message via MSN to bachus_anonym
AMD's "cold-bug" sucks!!! *** SD 3700+ & DI fiasco ***
No, there's no OCing results this time Just a rant about AMD's cold-bug!!!
Let's start then...
Chapter One: Preparation.
1. Chilly1's DI/LN2 container that I got from Conrad to play with. Thanks a lot, bro
2. Besides seal string that I use on my phase change I decided to apply some Liquid Electrical Tape to the areas not covered with seal tape. Looks pretty messy but it's very effective
3. This is how I attached thermal probe to the bottom of the block...
4. Slowly getting ready to roll...
5. This what I saw while sitting in BIOS @ 3730Mhz 1.80vcore BIOS LOAD, meaning just normally loaded system, nothing extreme. Lowest I've seen was -68C while in BIOS... I did not takle a pic as I was kind of pissed then already
6. This is why it's great I decided to use Liguid electrical Tape Very slight condensation due to alck of airflow in that area. I forgot to direct fan in there After that I put 120mm fan in that area and problem was gone...
7. Quick cool shot of Acetone+DI boiling
8. Battlefielld after 3.5hrs of trying to get some decent fun with no success
9. Container without insulation - just a cool pic
... and nothing else to show ...
*** My observations about cold-bug ***
1. On my San Diego, it kicks in past -44C on a block. Any lower and I cannot get to Windows - it hangs past BIOS BACK-UP.
2. I can sit in BIOS at -64C on the block and at least 3730Mhz on CPU. Once I leave it, what above happens.
3. Once I get lucky to get into Windows I need to maintain constant LOAD - I used looped Sandra CPU Arithmetic Bench @ LOW Priority to do it. But even with that running, past -50C systems hangs
CONLUSION: On-die memory controller + 90nm process is the worst nightmare combination. I wish I was a bit more lucky and got some "healthy" chip
Anyone, feel free to post yur experiences with a DI/LN2 cold-bug and maybe any walkarounds or ideas
Thanks for looking and take care,
Michal
__________________
3ch 3x2GB WR - Dominator 2000C7GT @ DDR3-2560 7-8-7-20
bachus_anonym is offline   Reply With Quote
Old 07-07-2005, 11:55 PM   #2
Sucka
Sucka's Avatar
Great pics, too bad about lack of results. I wanted to do some DI myself here soon but this is discouraging now. I've seen other SD/Venices clock well under dice, just a "bad" CPU as far as cold bug is concerned?
__________________
DFI SLI-DR | Opteron 170 Mach II | 2x512 G.Skill LE | x1900XTX | 2x250GB Hitachi T7K250 RAID 0 | PCP&C 510 SLI | Creative X-Fi
My Heatware
Sucka is offline   Reply With Quote
Old 07-08-2005, 01:12 AM   #3
gbglassen
I really like your insulation Is that liquid tape easy to peel off or is it more or less permanent?
__________________
x800xtpe
9800xt
gbglassen is offline   Reply With Quote
Old 07-08-2005, 01:44 AM   #4
bachus_anonym
Corsair Engineering
You know what? I think it's just my CPU. We've seen quite a few San Diegos doing OK under DI. It just seems like the one I got is only good up to single stage...
Thanks Liquid Electrical Tape is very easy to remove. Just peel it off... Seal string is a bit more PIA because you need to be very careful not to pull any of the surface mount components off the mainboard. But it's still doable.
I don't think I will ever be selling this board. So I don't really care how it looks. I'll probably sooner kill it that sell it
__________________
Old 07-08-2005, 01:58 AM   #5
TheMeatFrog
Send a message via AIM to TheMeatFrog
Very cool stuff! Really too bad no testing fun.
The WR in my sig was set on Lestat's Chilly1 dice container much <3 chilly1
__________________
Intel C2D E6300
DFI Blood-Iron P35
2x1GB Crucial Ballistix PC8500
BFG 8800GT OC 512MB
Corsair HX520
Heatware
TheMeatFrog is offline   Reply With Quote
Old 07-08-2005, 02:05 AM   #6
conrad.maranan
Strictly Business
conrad.maranan's Avatar
When you're ready to retire from overclocking, let me know. We'll find another hobby that isn't as frustrating. And don't feel too bad. My chip didn't have the "cold bug" yet I still didn't manage to capture any screenshots. Sometimes, it's just not meant to be.
__________________
Brayden rules!
OVERCLOCKING - The process of installing high hopes, dumb luck, and several paychecks into a rectangular
box which transmits a signal to a screen that displays your fate. The outcome is usually depressing.
conrad.maranan is offline   Reply With Quote
Old 07-08-2005, 02:14 AM   #7
bachus_anonym
Corsair Engineering
Nice clock on that Venice You guys should have benched it a bit
I know, I know... I was really dissapointed to be honest. I really hoped to get even better Pi results, even though I knew I will have a problem even before I slapped the tube on it. Oh well... There's still some gardening left to do in the backyard.
In the mid-time I already put phase change back on. It looks like 3.4Ghz is all I'm gonna have to live with... Still, not too shabby
Once again, thanks for letting me play with Chilly1's sweet container, bro
__________________
Old 07-08-2005, 02:17 AM   #8
conrad.maranan
Strictly Business
Anytime, Michal. And if you do decide to grab another chip in the next week out of impulse, just hold on to the container until I finish moving in to my new house.
Peace.
__________________
Brayden rules!
Old 07-08-2005, 05:23 AM   #9
Dani
Dani's Avatar
My Venice 3200+ 0517BPEW had too that stupid coldbug...
1.) 2.9GHz stable with AIR cooling
2.) 3.24GHz stable with VapoChill LS
3.) 3.21GHz unstable with DryIce
Yep, anything above 3.2GHz/or -42ºC with DI freeze in Windows after SP8M, just f*cking great
__________________
- Team Skootterit
- SuperPi32M : 18m53.156s with FX-57 / LN2 (Ilkkahy's brazed container)
- SuperPi8M : 3m55.703s with FX-57 / LN2 (Ilkkahy's brazed container)
- SuperPi1M : 21.484s with FX-57 / LN2 (Ilkkahy's brazed container)
Dani is offline   Reply With Quote
Old 07-08-2005, 05:36 AM   #10
andL64
andL64's Avatar
Send a message via ICQ to andL64 Send a message via AIM to andL64 Send a message via Yahoo to andL64
well bachus i know how you feel
i also waited for a special stepping for bout 2weeks and modded my mach2 for the new core.....
i got it a venice 3200+ and it wouldnt even boot with my mach2 so i put the stock heatsink on and well it booted and was benchable up to 2750-2800 first tests.... so i decided to get an sd next day and well it booted with my mach2 get it up to 3200bench and 3340 suicide so i m happy now but i have to sell the venice which i cant need/use....
seEn
__________________
. . . WHO put this thing together? ME !
. . . WHO do i trust? ME !
. . . f*** it, as****
andL64 is offline   Reply With Quote
Old 07-08-2005, 10:27 AM   #11
bachus_anonym
Corsair Engineering
@Dani,
That blows! But nice insulation on that container.
I think I'm gonna wait a bit and start searching for another SD that will be a bit more immune
@andL64
I think that even if your CPU has a cold-bug it should still boot and work up to certain temperature. If it didn't boot up at all I would look elsewhere. Maybe mounting was not tight enough and and some condensation prevented it from booting
__________________
Old 07-08-2005, 11:41 AM   #12
andL64
andL64's Avatar
yes i know, but the point is.....
the venice didnt boot with -5 or -10 even and the san diego works fine up to -25C now and it clocks really nice, so just try it with some decent cooling *lol* never believed i ll say this here on xsys. but its real a pain in the ass.
seEn
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
