XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 06-25-2005, 01:30 PM   #1
cinders
cinders's Avatar
Temps to run Dothan at in Laptop
Guys,
Can anyone advise me?...
I'm playing about with fancontrol on my inspiron, I'm just wondering what temperature bracket I should keep my Dothan running in?...
I believe the max operating temp of the Dothan is 60 deg C?...
At the moment I've set it the fan is off until it reaches 45 degrees then it kicks in on low speed, once it reaches 55 it kicks on full whack...
I've run S&M to really heat this baby up and with the above settings once it gets to 55 deg C and the fan hits full speed it never climbs above it.
Does this sound OK?...
Thanks,
Cinders.
__________________
Desktop:
Intel Q9550 SLB8V CPU un-opened in Box
Gigabyte EG45M-UD2H un-opened in Box
8Gb DDR2 Crucial Memory un-opened in Box
2 x 1Tb WD Caviar Green (RAID-1 Storage)
80Gb Intel X25-M SSD (System)
No Graphics Card (yet)
No PSU (yet)
No Case (yet)
Laptop:
Lenovo Thinkpad X200s
4Gb DDR3 Ram
cinders is offline   Reply With Quote
Old 06-25-2005, 01:39 PM   #2
Moonman
Moonman's Avatar
Sounds good to me.
__________________
Moonman is offline   Reply With Quote
Old 06-25-2005, 05:08 PM   #3
Wrench
I use this program to slightly undervolt my Centrino, it gives me extra 45 minutes of battery life and lowers the temps.
http://www.pbus-167.com/
Wrench is offline   Reply With Quote
Old 06-26-2005, 12:18 AM   #4
cinders
cinders's Avatar
Hi Wrench, have you looked in to swapping a 400FSB Dothan in to a 533FSB board to O/C?... I've got a 745 on order which, hopefully should turn my 1.73Ghz 9300 in to a 2.44Ghz Beast! (he touches wood)
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Old 06-26-2005, 02:48 AM   #5
Wrench
Yeah I was thking of geting the 1.8 400fsb dothan and reflashing my lappy to older bios I would get 2.5ghz.
Old 06-26-2005, 11:54 AM   #6
victor89
victor89's Avatar
undervolt is good idea
victor89 is offline   Reply With Quote
Old 06-26-2005, 05:39 PM   #7
Highland3r
Send a message via MSN to Highland3r
Max temp for the dothans is 100°C iirc so plenty of room to go yet
__________________
.:. X2 @ 2.9 .:. E6600 L628 @ 4.73 .:. AB9 @ 512 FSB .:. E6300 @ 100% OC Stable
U.K. overclockers: Represent your country, bench for EP-UK! Unite and show the world there IS a U.K. scene!
Highland3r is offline   Reply With Quote
Old 06-27-2005, 02:40 AM   #8
Wrench
Damn skippy especially when you gain 30-45 minutes on your battery.
Old 06-27-2005, 08:23 PM   #9
Jayw28
which boards are good for o/cing on desktop anyway?
Jayw28 is offline   Reply With Quote
Old 06-27-2005, 09:09 PM   #10
totensiebush
Banned
the odds of managing 2.5 on stock vcore and laptop cooling aren't that great. a 1.6/2.13 is much more likely to work, a 1.7/2.26 is fairly likely to work. and wouldn't it be 1.8/2.4?
totensiebush is offline   Reply With Quote
Old 06-28-2005, 12:14 AM   #11
Martijn13
Go for DFI boards...
Martijn13 is offline   Reply With Quote
Old 06-28-2005, 03:31 AM   #12
cinders
cinders's Avatar
I've got a 1.8 on it's way from the USA... Should have it next week, I'm hoping to get it to run in my laptop at 2.4 - we shall see!...
It's worth a try!
__________________
Desktop:
No PSU (yet)
No Case (yet)
Laptop:
4Gb DDR3 Ram
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
