XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 05-17-2005, 10:59 PM   #1
Soulburner
Just deleted over 900 PMs
Soulburner's Avatar
A64 + Multitasking = ?
Is it just me or is multitasking performance really bad?
If I try to run 2 clients of any game it takes forever to get the 2nd one going, or any heavy CPU loading task for that matter will slow the system down very noticeably. On my Intel, it wasn't so, it was tons smoother and faster, even with a slower CPU (2.4c vs my new San Diego).
Am I doing something wrong?
__________________
Desktop:
NZXT Zero
Central Processing: ABIT IP35 Pro / Core 2 Duo E6850 @ 3.6Ghz / 4GB G.Skill F2-8000CL5D-4GBPQ
Cooling Station: Enzotech Ultra-X / Sharkoon Silent Eagle 120mm / Modded IP35 Pro Heatsink System
Storage Subsystem: WD Raptor 150GB / WD Caviar 640GB / WD GP 1TB / Samsung 18x DVD-R/RW
Networking Department: D-Link DIR-655 / Realtek Gigabit NIC
Visual Processing and Display: EVGA GTX 260 896MB Superclocked / BenQ 24" 1920x1200 LCD
Tonal Processing and Delivery: Auzentech X-Fi Prelude / Onkyo TX-SR304 / Athena S.5 5.1 / Velodyne VX-10
Peripheral Input: Razer Deathadder / Logitech LX710 / Steelseries 5L
Power Delivery: Corsair 620HX / APC BX1300LCD UPS
Midnight Blue Dell Inspiron 1720
Core 2 Duo T7500 @ 2.2Ghz
4GB PQI PC6400
NVIDIA 8600M GT 256MB @ 625/1250/1024
WD Scorpio 250GB (5,400RPM)
17" 1920x1200 LCD
< Nikon D300 >
Soulburner is offline   Reply With Quote
Old 05-17-2005, 11:08 PM   #2
koei
No, its perfectly normal. Most P4 has HT which allows them to handle two threads where as P4 without HT or AMDs can only handle one thread at a time. When it comes to high load multi-tasking situation, the difference will be noticable. I don't think many ppl run two games at a time so it really isn't a big deal to them, but if you do want to go nuts doing that, you are better going with a P4 instead.
__________________
Main: i7 920 D0 @ 4.20GHz, GIGABYTE EX58-UD5
3x2GB OCZ Reaper 1866, Sapphire 4870x2 2GB
3x30GB OCZ Vertex RAID-0, Corsair CMPSU-850TX
Swiftech Apogee GTZ, MCP355, MCR220
Server: Phenom II X4 940BE @ 3.60GHz, GIGABYTE MA790X-UD4P
2X2GB OCZ Platinum 1066, HIS HD2600XT 256MB
1TB WD Caviar Black, 2x1.5TB Seagate Barracuda, SilverStone ST50EF
Media: Phenom II X4 940BE @ 3.50GHz, Biostar TA790GX XE
2X2GB Kingston HyperX T1 1066, VisionTek HD4850 512MB
1TB WD Caviar Black, SilverStone ST400
koei is offline   Reply With Quote
Old 05-18-2005, 12:29 AM   #3
Soulburner
Soulburner's Avatar
/awaits the X2
__________________
Desktop:
NZXT Zero
4GB PQI PC6400
17" 1920x1200 LCD
< Nikon D300 >
Old 05-18-2005, 12:34 AM   #4
Monkeyyy
/awaits the X2 which is affordable (under 400 at least)
Monkeyyy is offline   Reply With Quote
Old 05-18-2005, 01:30 AM   #5
TuKo
TuKo's Avatar
Send a message via ICQ to TuKo Send a message via MSN to TuKo
/me awaits any X2
__________________
Gigabyte X58-UD5| Core i7 920
GTX 275| 6Gb Kingston PC10600
4xSamsung 32GB SSD RAID0
640Gb+320GB+750GB HDD
Corsair HX850
TuKo is offline   Reply With Quote
Old 05-18-2005, 01:34 AM   #6
$a1Ty
why would you want to load two games at a time, last time i checked i can only concentrate at one game at a time
unless your like my friend who opens multiple sessions of ragnarok so he can have all his accounts open at once lmao
$a1Ty is offline   Reply With Quote
Old 05-18-2005, 02:35 AM   #7
koei
I do recall having "boxed" multiple characters back when I played EverQuest. Although, I was doing it on an AthalonXP at first. I switched to a P4 2.8E later on and it handled it much better than the XP mainly due to the HT. But really, besides that, I don't see much point of having two or more threads capable CPU unless more applications and games are programmed to take advantage of it like the next generation game consoles.
__________________
Old 05-18-2005, 03:02 AM   #8
w0203j
Send a message via MSN to w0203j
Why not X2? It is designed for muilt-threads task, and you will still get very strong game preformance.
w0203j is offline   Reply With Quote
Old 05-18-2005, 12:47 PM   #9
Rudzer
Yep I find multitasking performance a bit crappy that is bound to change bigtime with X2 tho
__________________
Ever stop to think, and forget to start again?
Rudzer is offline   Reply With Quote
Old 05-18-2005, 01:18 PM   #10
burningrave101
AMD's X2 is dual core and the performance in single threaded applications like most games today will be pretty much the same as what you would get with a single core Athlon 64 that runs at the same speed as each of the cores in the X2. The main difference is that you will be able to get that same performance with like 50% or 60% CPU load instead of 90% or 100% which gives you the ability to multitask ALOT better.
burningrave101 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
