XtremeSystems Forums
Reply
Old 05-02-2005, 06:13 PM   #1
Arkangyl
Arkangyl's Avatar
Pump question
Hokay, I've found a MCP600 rev. 2 for $45 shipped, which sounds pretty good to me. But I'm wondering, how will the MCP600 r2 perform compared to a MCP350 or MCP650? I checked the systemcooling.com reviews of each, the MCP600 review gave the MCp600 lower numbers than the MCP600 got in other reviews (point, in the MCP600 review it was a 7' head, 165gph pump, in MCP350/650 reviews it was a 10' head, 185gph pump) and I'd like to know what to expect.
Basically though, if I want to make a good WC loop should I get the MCP600 rev. 2 for $45 or get an MCP350 or 650 (once the 350 is modded they seem rather similar in all applicable ranges, 4' to 8' on the PQ)
thanks
edit::
system :p
MCW 6002-64 (might go to TDX or other jet block soon)
Maze 4 (6800 Acelate top)
double heatercore
also how quiet is the MCP600? thanks
__________________
i7 920 @ 3.7ghz || Bloodrage || 6gb Pi Black || GTX 260+ || Xonar STX || 300gb VRaptor || U2-UFO
PA 120.3 & MCR-220 || DDC-3.2 XSPC || EK LT|| XSPC FC GPU
Arkangyl is offline   Reply With Quote
Old 05-02-2005, 06:30 PM   #2
nikhsub1
Xtremely Wet
nikhsub1's Avatar
Send a message via AIM to nikhsub1
I'd get the new rev MCP650, better reliability than the 600 and nearly identical in head, perhaps even more than the 600. It is supposed to be quiet now too.
__________________
*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
Q6600 @ 3.7Ghz / Maximus Formula X38 / 4GB Supertalent 6400 / 4870 HD
PC Power & Cooling 750W
Mountain Mods U2-UFO Cube
GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
Win7
"Artificial intelligence is no match for natural stupidity."
Originally Posted by ranker View Post
Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
nikhsub1 is offline   Reply With Quote
Old 05-02-2005, 06:49 PM   #3
Arkangyl
Arkangyl's Avatar
Yea, I saw the thing about the MCP650 r.2 being really quiet. Also the 350 is small :p
but $45 for a MCP600 seemed pretty nice to me.. and I'd rather not spend more than i ahve to
__________________
Old 05-02-2005, 07:09 PM   #4
MaxxxRacer
Xtreme X.I.P.
MaxxxRacer's Avatar
Send a message via AIM to MaxxxRacer Send a message via MSN to MaxxxRacer
the numbers on the systemcooling review are a bit odd... if u look at the 50Z review they ahgve (which is the new mcp600's) they get better numbers from systemcooling.. odd if u ask me.. i talked to the reviewer about it and he wasnt sure why it was the case.
for 45 dolllars id go with the 600..
MaxxxRacer is offline   Reply With Quote
Old 05-02-2005, 09:24 PM   #5
shadowing
XS News
Send a message via AIM to shadowing
I'd go with the 600. After all, no one has even tested the new revision of the MCP650. For the money, the 600 is better.
shadowing is offline   Reply With Quote
Old 05-02-2005, 10:25 PM   #6
MaxxxRacer
Xtreme X.I.P.
MaxxxRacer's Avatar
Ill see what i can do about testing the mcp650 pretty soon.
Old 05-02-2005, 11:54 PM   #7
Psyche911
To clarify, it looks like the official name is MCP655 from the two sites selling it so far. Can we use this name to clarify which one we're talking about? Thanks...
Psyche911 is offline   Reply With Quote
Old 05-03-2005, 05:58 AM   #8
Arkangyl
Arkangyl's Avatar
Thanks for the advice guys :p I bit the bullet and bought the pump since I need one and my budget is a little tight at the moment
__________________
Old 05-03-2005, 07:17 AM   #9
zeebs
zeebs's Avatar
Thanks Max
zeebs is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
