XtremeSystems Forums
Reply
Old 03-31-2005, 05:05 PM   #1
ed.howell
Could I use MCP650 and MCP600 in series??
I currently have a MCP650, Weapon 302 Heatercore and shroud, MCW6002, and MCW50 using 1/2 I.D tubing. I bought a MCP600 from a member on another forum, it took a poop and I just got a new one from Swiftech (Excellent Customer Service by the way). I got the 600 cause it is quieter, but I was thinking maybe I could run them in series. Would I see any temp drop?
Thanks in advance.
Ed
__________________
920 DO @ 4015Mhz 191X21 1.280Vcore HT on, Speedstep, Energy Saver and all other settings enabled!!
MCP600--Dangerden heatercore--Apogee GTZ--Weapon heatercore back to the pump with a T-line. All fans are 120mm Sanyo Denki San ace's--Temps between 56-61C
Asrock X58 Xtreme, 6GB Corsair XMS3 1530Mhz 8-8-8-24 1.639V, QPI-3441Mhz, NB-3441Mhz, VTT-1.27, CPU PLL-1.82
Evga 260 Superclocked
Corsair 620HX PSU
Windows 7 Ultimate 64bit
8 Seagate internal HD's totalling 2.5TB, Need to consolidate to fewer larger drives!!
2 Seagate external HD's also totalling 2.5TB's
The Original CM Stacker Case
Heatware
ed.howell is offline   Reply With Quote
Old 03-31-2005, 08:24 PM   #2
MANmitch
I believe you can run the two in a series, but it isn't recommended.
MANmitch is offline   Reply With Quote
Old 03-31-2005, 09:40 PM   #3
jinu117
-100c Club Member
I don't see why not? Go for it.
__________________
http://www.vapoli.com/Images/Forum/vapoli.jpg
Single Stage Work Logs
Originally Posted by killermiller View Post
Those ccb's will die if you look at them wrong.
heatware: jinu117
jinu117 is offline   Reply With Quote
Old 03-31-2005, 10:36 PM   #4
MaxxxRacer
Xtreme X.I.P.
MaxxxRacer's Avatar
Send a message via AIM to MaxxxRacer Send a message via MSN to MaxxxRacer
yah u can without issue. it wont hurt a thing.
MaxxxRacer is offline   Reply With Quote
Old 04-01-2005, 12:37 AM   #5
a5h
a5h's Avatar
Send a message via ICQ to a5h
i wouldn't ...i doubt they have the same specs. one would slow the other down i wud think.
i would make 2 loops ...1 for ur CPU and one for ur GPU.
a5h is offline   Reply With Quote
Old 04-01-2005, 04:08 AM   #6
ed.howell
Maybe I will just sell the 650 and get another 600. If I ran 2 pumps in series, whether it was a 650 & 600 or 2 600's would I see a temperature drop with my setup?
Thanks,
Ed
__________________
Corsair 620HX PSU
Heatware
Old 04-01-2005, 04:15 AM   #7
MaxxxRacer
Xtreme X.I.P.
MaxxxRacer's Avatar
yah u would. overvolting one of them would be the better option though. one 600 overvolted provides a little more performance than two of them as it is less heat dump with increased flow. the flow isnt as much as two of them but its increased by around 25 percent from stock. this is at 13.8 volts.
Old 04-01-2005, 05:33 AM   #8
ed.howell
How can you overvolt it?? Max I would want to run my 12V rail 24/7 is about 12.5 or so. Could I put something in line that would raise the voltage just to the pump?
__________________
Corsair 620HX PSU
Heatware
Old 04-01-2005, 05:58 AM   #9
eva2000
Memory Addict
eva2000's Avatar
i run exactly this MCW6002 with MCP650+MCP600 in series with Thermochill 120.3 with 12v rail at 12.38v with no probs I did this as i have very long tube length on external water cooling setup and Colder quick disconnects within the loop
eva2000 is offline   Reply With Quote
Old 04-01-2005, 07:05 AM   #10
ed.howell
Did it drop your temps any?? having the 2 pumps in series.
__________________
Corsair 620HX PSU
Heatware
Old 04-01-2005, 10:00 AM   #11
Premmer
Yes, order a Mean Well Model SD-25A-12 DC-DC Converter priced $23.61 plus shipping. Converter is rated at 25.2W, 2.1A @ 12Vdc. Its physical size is slightly less than 4-in square and is ~ 1.4-in in height. Input voltage range is 9.2V to 18Vdc. Adjustable output voltage range is 11V to 16Vdc, which is ideal for the Swiftech MCP600 operating at 14.0V There is an 8-week lead-time on delivery.
Link to supplier's website:http://www.cdiweb.com/PortalProductD...d=258354&fmt=1
You can open/download the converter data sheet which has all the details one could possibly want/need.
__________________
Intel E6850||Asus P5B Deluxe||2x Crucial Ballistix 1G DDR2 800 4-4-4-12||4 x Seagate 7200.10 250G HDD SATA II||
Hitachi 80G HDD SATA II Backup||ATI X1300XT 256MB||Corsair HX 520W||Tuniq Tower||3.9Ghz Vcore1.50||Ultimate 32-bit OEM
Premmer is offline   Reply With Quote
Old 04-01-2005, 10:05 AM   #12
ed.howell
thanks a lot for the info!! Can you overvolt a 650 also?? Or how about 2 600's in series at 14volts
__________________
Corsair 620HX PSU
Heatware
Old 04-01-2005, 10:36 AM   #13
Premmer
I don't know if you can OV the 650. In the case of dual 600s, order Mean Well SD-50A-12 @ ~ $30 from same supplier. This model is in stock as I just ordered/received one.
__________________
Old 04-01-2005, 11:18 AM   #14
ed.howell
Thanks.
Just checked on the 50A, they have 0 in stock. So 8 week lead time on that one also.
Would I notice a temp difference though??
__________________
Corsair 620HX PSU
Heatware
Old 04-01-2005, 11:50 AM   #15
Premmer
[quote=ed.howell]Thanks.
Would I notice a temp difference though??[/QUOTE
Their website may note zero stock on the SD-50A-12, but when I called their 800 number I was told that I should receive it within 10 days and I did. I also have an order for the SD-25A-12. That model will in fact take ~ 8 weeks to receive.
As for the temperature difference, suggest you pose the question on the Procooling Forum. There are some real experts there that respond with factual information. If you do, suggest you supply as much relavent detail as possible about your system's cooling configuration.
Question I posed on another forum:
What is the maximum operating voltage of the Swiftech MCP 600 pump? I'm using the NexXxos XP and wonder if it is worth the effort to build a compact dc-dc converter. Would there be a marked improvement in cooling efficiency if I operate the pump at a higher voltage and what might that voltage be?
Response from Cathar:
Typical operational range is around 10.0v - 14.9v.
Below 10.0v the DC motor inside stops spinning and the pump ceases to work at all.
At or above 15.0v the magnetic armature has a very high chance of magnetically decouple from the impeller, resulting in the motor spinning, but the impeller not spinning (i.e. the pump ceases to pump water). Under very carefully controlled conditions it is possible to get the pump up to 16.0v before magnetic decoupling pretty much always occurs.
14.0v is probably the "safest" over-voltage to run with. Above that and I'd say you're getting into serious pump life-span shortening territory, although I have no actual evidence to back that statement up, but rather is just a feeling. I could be totally wrong and it could kill the pump in a matter of months, but I don't think so as I've run an MCP600 here at 14.0v for about 6 months now without apparant problems.
Performance improvement depends on the radiator and waterblock in use, but somewhere around 0.3-0.6C would probably be a decent guideline of what to expect.
__________________
Old 04-01-2005, 12:30 PM   #16
ed.howell
WOW!
Thanks again for your information!!
__________________
Corsair 620HX PSU
Heatware
Old 04-04-2005, 12:19 AM   #17
eva2000
Memory Addict
eva2000's Avatar
don't know as i started with such a setup to begin with before it was single MCP600 with BA rad bought 2nd hand
Old 04-04-2005, 03:51 AM   #18
Butcher_
The specs on both pumps are for up to 14V operation so they should be fine overvolted. Series will work - you can use dissimilar pumps in series if you're not going to exceed the maximum freeflow of either of them (which you won't with those two pumps). Generally it's only a problem if you do something like put an eheim 1046 with an iwaki 30Z or something crazy like that.
__________________
CPU Temps: Forget MBM, if it don't crash it ain't too hot.
Butcher_ is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
