XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 03-30-2005, 04:41 AM   #1
ed.howell
Best 925XE overclocking board??
Well I think I might pull the trigger on a 925XE motherboard, PCI-E Graphics card and DDR2 ram. I already have my 570J ES chip. I was wondering which motherboard you guys recommend. Options are Abit Fatality, Asus P5AD2-E, or DFI 925X-T2 (I know this is a 925X, not sure if and when DFI is releasing the 925XE-T2). I will be pairing it up with 2X512 of OCZ PC2-4200 or PC2-5400 Platinum ram. I really like all the features available on the Asus board but does this board have a vcore droop problem like the P4C800E had? I don't want to have to mod the board. I have this 570J ES chip and would love to do 300+ FSB if possible.
Thanks in advance for your comments and suggestions.
Ed
__________________
920 DO @ 4015Mhz 191X21 1.280Vcore HT on, Speedstep, Energy Saver and all other settings enabled!!
MCP600--Dangerden heatercore--Apogee GTZ--Weapon heatercore back to the pump with a T-line. All fans are 120mm Sanyo Denki San ace's--Temps between 56-61C
Asrock X58 Xtreme, 6GB Corsair XMS3 1530Mhz 8-8-8-24 1.639V, QPI-3441Mhz, NB-3441Mhz, VTT-1.27, CPU PLL-1.82
Evga 260 Superclocked
Corsair 620HX PSU
Windows 7 Ultimate 64bit
8 Seagate internal HD's totalling 2.5TB, Need to consolidate to fewer larger drives!!
2 Seagate external HD's also totalling 2.5TB's
The Original CM Stacker Case
Heatware
ed.howell is offline   Reply With Quote
Old 03-30-2005, 09:20 AM   #2
ztop
Ed
mmmm ,,,, is better if you wait for dfi 925xe-t2
ztop is offline   Reply With Quote
Old 03-30-2005, 10:08 AM   #3
ed.howell
I wish I had a date or some kind of time frame to look forward to though.
__________________
Corsair 620HX PSU
Heatware
Old 03-30-2005, 11:35 AM   #4
macci
Xtreme Legend
macci's Avatar
ASUS board has fairly weak Vcore supply (ok for aircooling, might be a problem w/ phasechange). Also there is not much space between the PCIe and PCI slots (so your not going to put much extra video cooling there if you are useing any PCI cards). Other than that its probably an excellent board.
I'm useing the Abit Fatality mobo myself and really liked it so far. Only 4 SATA ports thou so it might be a problem and only one IDE. But very good voltage adjustments and strong voltage regulation. Just enough space to install CNPS-7700 too
Been up to 310FSB zone so far with the board and that's pretty much where this Gallatin 3.46EE maxes out.
Waiting for the DFI board.
Sampsa&Kamu used the Abit board in the latest SPi8M WR run
macci is offline   Reply With Quote
Old 03-30-2005, 11:59 AM   #5
ed.howell
Thanks Macci!!
Any idea when the DFI board will be out??? Also do you think you got lucky with that Abit board, cause I heard that it is a luck of the draw to get over 300FSB with the Fatality (not sure if it is true though)
__________________
Corsair 620HX PSU
Heatware
Old 03-30-2005, 12:25 PM   #6
macci
Xtreme Legend
macci's Avatar
I know three Fatality boards (mine, The Stilt's and Sampsa's) and they all do easily over 300. Shamino hit over 400 w/ Abit too?
Old 03-30-2005, 01:06 PM   #7
ed.howell
Ok thanks for the input!!
__________________
Corsair 620HX PSU
Heatware
Old 03-30-2005, 01:19 PM   #8
ztop
Shamino have the aa8xe non fatality board if i remember well....now on abit website there is a new bios n° 22 with bus 500
Old 03-30-2005, 08:14 PM   #9
Xassius
Xassius's Avatar
I vote for the P5AD2-E Although I agree with macci about power reg. It's unbeatable in features. Reaches 365mhz with ease too.
I heard DFI's not gonna bring out the 925XE in favour of 955x.
Xassius is offline   Reply With Quote
Old 03-30-2005, 09:18 PM   #10
AKURA
AKURA's Avatar
Abit AS8.......Hipro5 got some nice mods to make'm fly.
__________________
AKURA is offline   Reply With Quote
Old 03-31-2005, 08:19 AM   #11
AcUaViVa
xassius what cpu and what mem use for this fsb?
can you sen me the bios settings that you use
AcUaViVa is offline   Reply With Quote
Old 03-31-2005, 09:26 AM   #12
Salkcin
I think the knowledge is from various reviews where a engineering sample of a Extreme edition is used (minimum multiplier = 12x)... so 12x 365 = 4380MHz wich is'nt much overclock for a 3.73GHz CPU.
The example of 400MHz FSB wich Shamino reached on a AA8XE it should be noted that the chipset was cooled to -50 celcius degrees
Salkcin is offline   Reply With Quote
Old 03-31-2005, 09:59 AM   #13
AcUaViVa
well with EIDO or something else you can LOW the multipler og 6XX series to 14x...
or not?
Old 03-31-2005, 05:42 PM   #14
calcal
aa8xe/aa8xe fatality
hands down
calcal is offline   Reply With Quote
Old 03-31-2005, 05:46 PM   #15
afireinside
I am Xtreme
afireinside's Avatar
Send a message via AIM to afireinside Send a message via MSN to afireinside
AA8XE... I want one
__________________
Phenom II 940 BE / ASUS M4A79 / HD5770
3808mhz CPU 2720mhz NB | DDR1088 5-5-5-15 | 975/1300
afireinside is offline   Reply With Quote
Old 03-31-2005, 06:01 PM   #16
oublie
oublie's Avatar
AA8XE non fatality non 3rd eye unless you like your toys.
__________________
oublie is offline   Reply With Quote
Old 03-31-2005, 06:26 PM   #17
Muppetmower
Heh I got a question, when are the Intel SLI coming?
Muppetmower is offline   Reply With Quote
Old 04-01-2005, 05:16 AM   #18
Xassius
Xassius's Avatar
or not?
that is right. Unfortunately, 14x is the lowest you can go on a prescott and this leaves non-phase changers in the dark if they want the highest fsb's.
As Abit and Asus 925XE both can reach 350mhz FSB with EASE (no extra nb cooling...etc..etc) 350mhz x 14x is just impossible for the watercooler (let alone air cooling).
Old 04-02-2005, 05:51 AM   #19
chainbolt
I have both P5AD2-E and the Fatality AA8XE. My 3.73 goes on both boards to exactly the same frequency 4.81 GHz. However, for 24/7 folding with 100% processor load, I found the Fatality stable at 4.4Ghz, and the Asus does only around 4.20 GHz. The Asus lacks active cooling on the NB, and its mosfet cooler gets extremely hot as well.
chainbolt is offline   Reply With Quote
Old 04-03-2005, 03:57 PM   #20
Xassius
Xassius's Avatar
So HOW was your 3.73EE not stable at 4.4Ghz on the P5AD2-E? Processor producing errors? Or did the system completely "cut-out"?
Do you think it was due to heat of mosfets or the heat of NB?
Old 04-03-2005, 11:35 PM   #21
daffy67
I'm happy with my AA8XE, 3.73EE@4200 Mhz on air.
__________________
Asus M2N32 SLI Wireless D/L-AM2 DC 3800+@2470Mhz
2x1GB XMS Pro 5-5-5-12@247Mhz-
Albatron 8800GTX
daffy67 is offline   Reply With Quote
Old 04-04-2005, 01:25 AM   #22
charlie
THE GENERAL
charlie's Avatar
wonder how the Neo MSI board is????
__________________
xtremespeakfreely.com
charlie is offline   Reply With Quote
Old 04-04-2005, 10:20 PM   #23
InvisGreenMan
Exactly my question charlie.
Also, has MSI unlocked the 266 and above FSBs for not 1066FSB processors? I also need more than 1.49Vcore from the MSI. Other than those two things I think I would spring for the MSI.
- keeping a close eye on this thread...soon to get a 925xe board.
__________________
In my Lian Li PC-V1100B:
A64 3200+ NC/CG 300HTT x8 2400MHz (SLK948U w/92mm H1B) ***watercooling also coming soon***
DFI Lanparty UT 250gb - 1Gb OCZ EB PC3500 - PCP&C 425 Deluxe
Sapphire Radeon 9600XT 128Mb (VGA silencer rev. 3) - SB Audigy LS
80Gb & 200Gb Seagate Sata Drives - Pioneer 16x DVD+-RW - Lite-On CDR/RW DVD-ROM
FOLDING!
InvisGreenMan is offline   Reply With Quote
Old 04-04-2005, 11:26 PM   #24
uclajd
uclajd's Avatar
Watching this thread also...
__________________
<----- REST IN PEACE, KIT. 1993-2007.
uclajd is offline   Reply With Quote
Old 04-05-2005, 12:55 AM   #25
Xassius
Xassius's Avatar
don't think it's that good. Well...no one's tried it with amazing results...yet.
ATM....Abit and Asus rule the i925XE crowd...
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
