i have my first system running. its a huge 1hp compressor, its too expensive to run 24/7.
so now i want to make a new system, really compact, low powered and i want to fit it inside my lian li pc6010 (i know it will be a tight fit buy i think its possible).
i started looking around, and found some compressors that will fit. i found a 1/5hp unit, a 1/6hp unit and a 1/8hp unit.
i want to know if someone has tried to make a DD system running with a compressor of this power.
the good thing is that i wont be expecting really low temps. having -10c under load is more than enough. im considering using R22+R290 on a R12 compressor.
this are the units ive been looking at, so far:
http://www.buenosaires.ansal.com.ar/...dfs/575101.pdf
http://www.buenosaires.ansal.com.ar/...dfs/576012.pdf
http://www.buenosaires.ansal.com.ar/...dfs/576024.pdf
