03-06-2005, 03:09 PM
#1
MCP600 runs HOT??
I just installed an MCP600 I bought and the housing is HOT to the touch. Is this how it is supposed to be??
Thanks,
Ed
__________________
920 DO @ 4015Mhz 191X21 1.280Vcore HT on, Speedstep, Energy Saver and all other settings enabled!!
MCP600--Dangerden heatercore--Apogee GTZ--Weapon heatercore back to the pump with a T-line. All fans are 120mm Sanyo Denki San ace's--Temps between 56-61C
Asrock X58 Xtreme, 6GB Corsair XMS3 1530Mhz 8-8-8-24 1.639V, QPI-3441Mhz, NB-3441Mhz, VTT-1.27, CPU PLL-1.82
Evga 260 Superclocked
Corsair 620HX PSU
Windows 7 Ultimate 64bit
8 Seagate internal HD's totalling 2.5TB, Need to consolidate to fewer larger drives!!
2 Seagate external HD's also totalling 2.5TB's
The Original CM Stacker Case
Heatware
03-06-2005, 03:12 PM
#2
mines warm to touch I barely feel any heat coming from the housing...
03-06-2005, 03:14 PM
#3
I cannot even put my finger on the housing. It is REALLY HOT!!!
__________________
Corsair 620HX PSU
Heatware
03-06-2005, 03:36 PM
#4
Mine also just feels warm to the touch. I would guess maybe 10° above ambient.
03-06-2005, 04:33 PM
#5
A friend of mine uses this pump, it does not run as hot as you've described.
03-06-2005, 05:00 PM
#6
If yours is running that hot, then you need to contact swiftech. You have problems.
__________________
Proud of my Pontiac G8.
...Yes, I know that its a Holden...
If you hate it, you haven't driven it.
03-06-2005, 05:05 PM
#7
It seems to have cooled down a little bit. I will keep checking it and see how it's doin.
__________________
Corsair 620HX PSU
Heatware
03-06-2005, 05:35 PM
#8
Xtreme X.I.P.
very strange.. make sure ur getting good flow and nothign is clogged.. that will heat up a pump more.. i know when i switched to bigger tubing on my iwaki it runs cooler now due ot increased flow.
03-06-2005, 06:28 PM
#9
It cooled WAY down now barely warm. maybe there was still some air that needed to be worked out of the system.
Oh well thanks for the help everybody
__________________
Corsair 620HX PSU
Heatware
03-06-2005, 08:53 PM
#10
my aqua x 50Z runs slightly warm but not hot
__________________
|Core 2 Duo E8400 @ 3.6GHz|DFI DK P35-T2RS|8.0GB G.skill PI PC2-6400|MSI GTX 260|
|HP LP2465 24" LCD|Antec P182|OCZ 600w PSU|H2O Cooling|Windows 7 x64|
|Core 2 Duo E6420|Asus P5K-VM|4.0GB DDR2|AMD Radeon 3450|Antec Fusion V2|Westinghouse 42" 1080P LCD|
|ThinkPad X61 Tablet|Core 2 Duo L7500|4.0GB DDR2|OCZ Vertex SSD|Windows 7|
Audio: EMU 0404->Onkyo TX-SR500 ->Polk LSi7's + Velodyne VX10
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
