What causes ram to pass memtest booted from cd but not in Windows??
I am running into a problem. I can pass memtest booting from a cd with my OCZ PC4200El Platinum's 2.9volts 2.5-3-3-8 at 285FSB no problems, but I when I run Memtest in Windows, I am having trouble getting it to pass at between 270-275 with the same voltage and timings.
Why does this happen?
Also I have the DFI 875P-T mobo and it just has passive cooling on the NB, would putting active cooling on the NB help a lot? I am assuming it would but just want to make sure.
Thanks,
Ed
__________________
920 DO @ 4015Mhz 191X21 1.280Vcore HT on, Speedstep, Energy Saver and all other settings enabled!!
MCP600--Dangerden heatercore--Apogee GTZ--Weapon heatercore back to the pump with a T-line. All fans are 120mm Sanyo Denki San ace's--Temps between 56-61C
Asrock X58 Xtreme, 6GB Corsair XMS3 1530Mhz 8-8-8-24 1.639V, QPI-3441Mhz, NB-3441Mhz, VTT-1.27, CPU PLL-1.82
Evga 260 Superclocked
Corsair 620HX PSU
Windows 7 Ultimate 64bit
8 Seagate internal HD's totalling 2.5TB, Need to consolidate to fewer larger drives!!
2 Seagate external HD's also totalling 2.5TB's
The Original CM Stacker Case
Heatware
