XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 02-23-2005, 08:57 AM   #1
ed.howell
Life of Intel ES chips??
Maybe a dumb question but here it goes.
I have a chance to get a 570J ES chip and I was just wondering if these ES chips have any problems or issues? I don't plan on keeping it forever but want to make sure that if I kept it for 8 months to a year that I wouldn't have any problems.
Thanks a lot
Ed
__________________
920 DO @ 4015Mhz 191X21 1.280Vcore HT on, Speedstep, Energy Saver and all other settings enabled!!
MCP600--Dangerden heatercore--Apogee GTZ--Weapon heatercore back to the pump with a T-line. All fans are 120mm Sanyo Denki San ace's--Temps between 56-61C
Asrock X58 Xtreme, 6GB Corsair XMS3 1530Mhz 8-8-8-24 1.639V, QPI-3441Mhz, NB-3441Mhz, VTT-1.27, CPU PLL-1.82
Evga 260 Superclocked
Corsair 620HX PSU
Windows 7 Ultimate 64bit
8 Seagate internal HD's totalling 2.5TB, Need to consolidate to fewer larger drives!!
2 Seagate external HD's also totalling 2.5TB's
The Original CM Stacker Case
Heatware
ed.howell is offline   Reply With Quote
Old 02-23-2005, 09:19 AM   #2
Shane5578
some poor quality mobos cant adjust multi's properly.
other than that. they are as excellent cos they are unlocked
i've had my 3.2es for 3 years now. its currently been under a vapo for the past year. they are robust cpus
btw i got 3 other es cpus and i expect them to last 100years
__________________
Stick a Vapo on it
Shane5578 is offline   Reply With Quote
Old 02-23-2005, 09:22 AM   #3
ed.howell
Cool thanks,
I will be using it with my DFI 875P-T, I wouldn't consider that low quality would you!!
Thanks again
Ed
__________________
Corsair 620HX PSU
Heatware
Old 02-23-2005, 10:00 AM   #4
perkam
Live Long And Overclock
perkam's Avatar
Send a message via MSN to perkam Send a message via Yahoo to perkam
ES = Engineering Sample...no?
Perkam
__________________
Star Trek Online Open Beta
Name: Captain Maxentius
Rank: Lt.
Ship: USS Kira
Class: Miranda-Class
Preferred Class: Akira-Class
perkam is offline   Reply With Quote
Old 02-23-2005, 11:42 AM   #5
Xerxes
well it depends on the es, most are perfectly fine and others have minor defects that wouldnt pass normal qa, though those tend to be rarer now than a few years ago.
Xerxes is offline   Reply With Quote
Old 02-23-2005, 12:52 PM   #6
madman2233
Perkam
correct, meaning they are unlocked
btw, ed.howell,
do you by chance live in howell?
__________________
Phenom 9600 --MSI K9A2 CF --XFX 5870 --6gb GSkill --Scyth Infiniti --750GB and 500gb SATA
madman2233 is offline   Reply With Quote
Old 02-23-2005, 01:14 PM   #7
quicksilverXP
how many multis are unlocked?
quicksilverXP is offline   Reply With Quote
Old 02-23-2005, 01:19 PM   #8
ed.howell
btw, ed.howell,
LOL no I don't.
Mulit's that are available on this chip are 14-19
__________________
Corsair 620HX PSU
Heatware
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
