01-21-2005, 06:17 AM
#1
I'm gonna pull my heatspreader of my FX55
this weekend, I was wondering, can you buy a shim that will protect me from mashing the core up when I put the heatsink on?...
__________________
Desktop:
Intel Q9550 SLB8V CPU un-opened in Box
Gigabyte EG45M-UD2H un-opened in Box
8Gb DDR2 Crucial Memory un-opened in Box
2 x 1Tb WD Caviar Green (RAID-1 Storage)
80Gb Intel X25-M SSD (System)
No Graphics Card (yet)
No PSU (yet)
No Case (yet)
Laptop:
Lenovo Thinkpad X200s
4Gb DDR3 Ram
01-21-2005, 06:53 AM
#2
why are you doing this??? I don't think's its even close to worth if it your water cooling it. It will make just about no difference in your OC.
My $0.02, but maybe you don't care. Good luck, lets see pics if you do.
__________________
I like building Vapor phase coolers......
......to cool mynipples!!
Heat is "gclg2000"
95-0-0
-100C Cascade Club
#3
Xtreme X.I.P.
no shims for a64 yet. no need for them. a good tip is to put maskign tape over the little IC's around the core. the heatsink will have a tendecny to tip and toch them, shorting them out.
good luck btw. hope u dont kill it like i did.
01-21-2005, 06:57 AM
#4
Xtreme 3DTeam Member
 Oooops - You might look out for a grave digger - chances are high You'll have to burry Your FX...........
01-21-2005, 07:36 AM
#5
I really don't think so ! Just be carefull and do it very slowly. If you feel a cash module with the knife stop imediately.
01-21-2005, 07:40 AM
#6
THE GENERAL
it really takes GRAPEFRUITS to lop the IHS off of your new $1000 proc.
C
01-21-2005, 07:41 AM
#7
I wouldn't do it either. I know people like to do extreme things, but that's going overboard.
__________________
Abit IC7 Max3, P4 3.4c, 2x512 Corsair PC3200XLPro, BFG 6800GT, Seagate 72gig Cheetah
Asus A8V, FX53, 2x512 Corsair PC3200XLPro, BFG 6800 Ultra Water, Koolance Exos AL, Seagate 72gig Cheetah
01-21-2005, 07:44 AM
#8
Well this is XS, heheheeee
__________________
24/7 Settings
Tagan TG1100-U33 1100w
DFI 790FXB-M2RSH
PhenomII X4 965 C3 0944APMW
4000mhz | 1.520v | 200 x 20 |1066mhz | 5-5-5-15-24
D-Tek Fuzion V2 | Thermochill HE120.3 | Swiftech MCP655 D5
OCZ (2x2GB) PC2-8500C5 Platinum Series
ATI HD3400 256MB
01-21-2005, 07:48 AM
#9
Xtreme X.I.P.
XS= Xtreme Suicide....
01-21-2005, 07:50 AM
#10
xtreme suicide is what i would do if i botched my 1000 dollar fx-55 doing something retarded like that, i wouldn't personally
01-21-2005, 07:56 AM
#11
XS Local
if anything id remove it to put as5 or as3 on the core between the HS.
__________________
Opteron 175 Dual Core CCBWE 0544XPMW @2.3ghz 1.41v
DFI SLI-DR Expert 11-25 Bios
G-Skill 1gb GH UTT @210 2-2-2-5
BFG 7800GT OC 485/1170 NV 5rev3
74gb Raptor 300gb Maxtor 500gb Hitachi
OCZ 520w SLI 3.46v 5.16v 12.64v
Thermaltake CL-P0114 Big Typhoon
3dmark01 3dmark05
Heatware
01-21-2005, 08:13 AM
#12
Xtreme X.I.P.
well how would u get it back on dissolved. I tried that with my winnie and it didnt work... it is going to the UK now for ritualistic disection.
01-21-2005, 08:14 AM
#13
XS Local
well ive never taken one off, but theres not thermal paste between the ihs and core?
__________________
3dmark01 3dmark05
Heatware
01-21-2005, 08:24 AM
#14
On winchester cores it will gain you a 50mhz +...on newcastle...it won't gain you that much... I got 2 times 20mhz gain on newcastle cores.
__________________
System:
Opteron 165+ @ 3140mhz @1.5V aircooled
DFI NF4 Ultra-D
4X 512mb Speedpremium PC3500 new BH5
MSI 7900GTO 512MB @ GTX
2x WD 80GB raid 0 + 2x 300GB Maxtor
Channel Well Tech 550W
01-21-2005, 08:26 AM
#15
How fast did you 3000+ 0447 upcw go? 2 friends of my have 3200+ 0447 upcw...they both do 2850mhz boxed. And 1 now has watercooling with water of 10 degrees... It now does 2950Mhz!
__________________
System:
DFI NF4 Ultra-D
01-21-2005, 08:32 AM
#16
Thats the dumbest I have heard this year...
01-21-2005, 08:44 AM
#17
Warranty=pfft
Be careful man!!
I screwed up bad when I did a fx55. Pushed a little to hard with razor around the edges and I crunched the top off of one of the surface components
(not sure if resistor)
Chip still posted and ran fine at stock and mildly oc'd speeds, but it lost about 200mhz on its max overclock from 3514 to 3390....it's just a gamer now
01-21-2005, 09:03 AM
#18
Love and Peace!
just don't cut it with a knife if you're worried about the resistors. i used a piece of plastic from a package of eclipse gum. it was hard, but it worked just fine.
and to whoever said there is no thermal paste between the core and ihs.. that's not true, there is. it's really hard stuff though, almost like epoxy, but not.
and one thing to note, when i removed my ihs, i found the core was slightly rounded.. infuriated me to no end, so i ended up lapping the core.
__________________
Got a fan over those memory sticks? No? Well get to it before you kill them
01-21-2005, 09:46 AM
#19
XS Local
bah, neo2+ocz520w killed her... my neo2 just gave up after a few boots..
__________________
3dmark01 3dmark05
Heatware
01-21-2005, 09:59 AM
#20
Id be too ckicken sheet to do that..
GL with it tho..
__________________
#21
Do you have any pics of that?
01-21-2005, 10:40 AM
#22
XS Intel News & DČOL enhanced
same here !
01-21-2005, 01:59 PM
#23
Xtreme X.I.P.
lapping the core.. well that is rather dangerous... even more dnagerous than ihs removal. but luckily there is a thick layer of garbage over the real core as ai found out when it ook a hammer to my axp moible after it blew up.
01-21-2005, 03:21 PM
#24
Dumb idea. void any warranty..risk cutting though or cracking core.. That epoxy is a      to cut though..trust I've done it but on a $128 chip not a $1000 one...
BTW that machine on water too saw maybe 50mhz boost...
Risk vs reward = suck
__________________
Seeeeeeeeeeeeeeeed!!!!!!
01-21-2005, 03:36 PM
#25
Xtreme Cruncher
well what are u crying about?
just do it with feeeeeeeeling
nevertheless won't do it on my 3500+ either...no need when
it's cooled down by a mach I -.-
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
